Need Install on Greddy Pulley Set
Old Oct 12, 2008 | 05:01 PM
RX876's Avatar
Can someone tell me where I can find a DIY to install the Greddy Pulley Set. Also, I am buying it used and the person I am buying it from says it doesn't not come with any mounting hardward. He says they install with the existing bolts and the alternator has enough adjustment to use the same belt. Is this correct?
Old Oct 12, 2008 | 05:15 PM
I8U's Avatar
I8U
This is a very easy mod...hell my wife could do it!HAHA! Just use the existing bolts and you're good to go.
Old Oct 12, 2008 | 09:42 PM
Re-use everything.
Old Oct 15, 2008 | 08:58 AM
RX876's Avatar
Ok, so I just baught the pullies... install guys says $120 to install the two pulleys noting that it is a 2 hour job and he has to take the alternator off to install the alternator pulley. I didnt know these pulleys would be that much to install. Was he pulling my leg?
Old Oct 15, 2008 | 09:06 AM
Greenblurr93's Avatar
Sotally Tober
seriously, you should save yourself the money and install them yourself. As long as you have basic tools and common mechanical knowledge youll be fine.
Just unbolt the original and bolt on the greddy and put the belts back on.. easy as cake
UHATEIT
Dec 10, 2015 02:57 PM
bulletproof21
Oct 20, 2015 08:53 PM
rx8inator
Sep 1, 2015 07:18 PM
rx8inator
Aug 14, 2015 10:53 PM
