Burning plastic smell
Old Oct 3, 2008 | 09:26 AM
RX8Sinner's Avatar
Ok, i've searched and searched. Over the last like week or so i've noticed the smell of burning plastic. Havn't been able to pinpoint the source. I searched the forums and noticed most if not all was contributed to a plastic bag. YES! I've had a plastic bag stuck to my muffler but No, its not that one thats smelling. That was a long long time ago. Where else should I look for the smell? I looked under the car and didn't see anything, when the police stopped the traffic on the garden state parkway today to remove some debris, i think i noticed a thin thin thin cloud of whiteish smoke coming from the hood. I pulled over and popped the hood. the smell was fairly strong, giving me a headache, BUT i didn't find the source anywhere.
Any suggestions as to where to look for the burning plastic smell?
Old Oct 3, 2008 | 09:37 AM
Renesis07's Avatar
Vtak just kicked in yo!!
How many miles are on your car (new car smell possibly)?
Are you losing power (Failing Cat possibly)?
Are you sure its plastic (possible oil leak or trans fluid burning)?
Old Oct 3, 2008 | 09:49 AM
RX8Sinner's Avatar
its an 04 with 37000ish on it. I'm almost 100% sure its burning plastic smell. I added oil last night at a rest stop after getting gas but I know i didn't spill anything.
Old Oct 3, 2008 | 10:11 AM
CyberPitz's Avatar
Huge hole is huge
I ran over a plastic bag one time and it sucked onto the exhaust and just...burned. I still smell it after 4 months.
Old Oct 3, 2008 | 12:21 PM
kersh4w's Avatar
Hit & Run Magnet
pretty much yeah.
Old Oct 3, 2008 | 02:39 PM
RX8Sinner's Avatar
The reason I ask because when I got the original bag stuck to the exhaust but it stopped smelling awhile ago. Now theres a rather strong odor coming from the front end, thats why I was confused because when I looked I didn't see anything.
Old Oct 3, 2008 | 02:42 PM
CyberPitz's Avatar
Huge hole is huge
It might be just some 'leftover' bag burning still. Mine does that. It will stop smelling for a while, then out of nowhere smell.
Old Oct 3, 2008 | 03:37 PM
alnielsen's Avatar
Did you replace the cat back exhaust? It could be the bumper shrouds.
Old Oct 3, 2008 | 07:51 PM
RX8Sinner's Avatar
The car is completely stock save for the K&N Shortram. The smell was definatly coming from the engine bay. Wasn't able to find the source though when i've looked.
Old Oct 3, 2008 | 08:21 PM
On the monfold down pipe.
Old Oct 5, 2008 | 01:26 AM
RX8Sinner's Avatar
Ok so i found the source of the smoke, though not the burning plastic smell, though I didnt' smell it at all today while working. So the burning smell was probably the same source as the smoke.
I did an oil change today before work and noticed the oil filter was loose as all hell. To the point oil was leaking out and my dad was able to remove the oil filter without a problem. So i'm assuming the smoke was from the leaking oil, and the smell may have been too. The oil wasn't leaking too too bad, though I did realise I was adding more oil than normal lately. Hopefully the problem is fixed.
Old Oct 5, 2008 | 03:58 AM
rx8phase1's Avatar
wash the underside of ur car if the oil was leaking when u were driving the air would have thrown it through out the bottom of ur car it happened to me once it was all over my exhaust so everythime my pipes would get hot i woiuld smell the oil and see smoke, just sparay water under ur car and u'll see the oil residue coming off onto the floor
Old Oct 5, 2008 | 07:00 AM
04RX8man's Avatar
Rotary Powered Countryboy
yeah definately b sure to wash everything off or it will smoke for quite sometime depending on how bad it was
Old Jan 7, 2013 | 11:29 PM
dafiro03's Avatar
OP Im having the same issue now and just threw a CEL so im rather concerned about whats going on reading CEL tomorrow hopefully wont checkout bad news... did you find the reason why the smoke?
Old Jan 8, 2013 | 03:28 PM
tza0001's Avatar
Dum Spiro Spero
^You know that this is a 5 year old thread, right?. And yes he found the source of the smoke. It's been stated three post before yours.
Old Jan 9, 2013 | 12:36 PM
kustus's Avatar
the newbie
Hey now, at least he searched!!!!!!! Haha
Old Jan 9, 2013 | 03:44 PM
tza0001's Avatar
Dum Spiro Spero
^So he does not search either?
Old Jan 10, 2013 | 08:57 AM
kustus's Avatar
the newbie
No, I was just poking fun at the forum. Everyone gets on people who dont search, then about thread bumps. He searched, but didnt read? Oh well. To be somewhat constructive at least dafiro03 I would look check the cat and make sure you didnt hit anything to mess with a sensor. Make sure cat is healthy, and look into ignition system componets if they havent been replaced in schecduled maintenance.
Old Jan 10, 2013 | 10:16 AM
dafiro03's Avatar
I have been searching for days and no results ignition upgraded to BHR coils smell and white fumes coming from opposite side of the coil packs cat is good didn't hit anything the CEL was a misfire. did an oil change today... no more smoke still faint smell
Old Jan 10, 2013 | 10:19 AM
dafiro03's Avatar
I saw his response, no need to be "smart" tried everything mentioned before I posted
Old Jan 11, 2013 | 09:20 AM
tza0001's Avatar
Dum Spiro Spero
^Just joking man...Did you by any chance spilled oil while changing your oil? This could explain the smell and the smoke...I would uninstall the ignition and make sure everything is clean.
Old Jan 12, 2013 | 12:35 PM
kustus's Avatar
the newbie
Yeah go over every possible lead then reconnect everything. Has it happened more than once or what? Clear the codes and try again. Maybe a fluke or low octane fuel/bad batch of gas? I had a misfire onmmy car but its never happened again. So idk what it was exactly. But I triple checked it to make myself feel better.
Ovr-9000
Apr 7, 2016 11:19 PM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
chadsta
Sep 20, 2015 11:00 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
