WTBRotary!
10-01-2008, 11:18 PM
Does anyone have like good pictures to show me exactly where to jack the car up and how they did it, i wanta make sure i do it right, plus im kinda lost on where to jack it up also, thanks :D
View Full Version : Jacking the car up? WTBRotary! 10-01-2008, 11:18 PM Does anyone have like good pictures to show me exactly where to jack the car up and how they did it, i wanta make sure i do it right, plus im kinda lost on where to jack it up also, thanks :D kersh4w 10-01-2008, 11:20 PM jack the front up using the beams that run a few inches in from the side. jack the back up with the rear differential. i'd love to know better places to jack the front up with. i hate scratching the beams. WTBRotary! 10-01-2008, 11:23 PM i thought 05' AT's didnt have the limited slip rear differentials??? i might be confused...lol tunerwannab 10-01-2008, 11:27 PM i thought 05' AT's didnt have the limited slip rear differentials??? i might be confused...lol It still has a differential, unless you got the FWD option.:uhh: Guy Hollywood 10-01-2008, 11:43 PM Should show you right in the manual. The section about changing a flat. WTBRotary! 10-02-2008, 12:20 AM It still has a differential, unless you got the FWD option.:uhh: right... aight well thanks heh... well ill hop to it... mikesol 10-02-2008, 01:36 PM If I'm just changing over to my winter rims, is it acceptable to just use the jack that comes with the car? tunerwannab 10-02-2008, 01:46 PM If I'm just changing over to my winter rims, is it acceptable to just use the jack that comes with the car? I wouldn't see why not. i would only lift one corner at a time with it though. and if you have jack stands I would still use them for safety. Guy Hollywood 10-02-2008, 02:18 PM If I'm just changing over to my winter rims, is it acceptable to just use the jack that comes with the car? Yeah, why not? That's what it's made for. Like Tuner said though, I would only do one corner at a time because I don't know how much weight it can hold at once. Like if you were trying to lift up the entire front end at once or something. That probably wouldn't be the best idea. And use jack stands for safety. You could even lift up each corner at a time and put a jack stand under each. Shouldn't be a problem having the car up on 4 jack stands. Just as long as they indicate that they can hold the weight! philsbluerx8 10-02-2008, 03:49 PM jack the front up using the beams that run a few inches in from the side. jack the back up with the rear differential. i'd love to know better places to jack the front up with. i hate scratching the beams. Jacking up the front IS difficult man, even an aluminum jack still doesnt fit into it when ur car is lowered. pdxhak 10-02-2008, 04:10 PM Drive up on 2x6 boards to help with clearance. Bastage 10-02-2008, 04:46 PM ^ +1 Or buy some ramps, they make getting under the car super-easy. You can get some decent ones at WalMart for like $25, and they stack for easy storage. Mr. Pockets 10-02-2008, 05:10 PM If I'm just changing over to my winter rims, is it acceptable to just use the jack that comes with the car? Personally, I wouldn't. Sure, the on-board jacks are fine in a pinch, but if it's not an emergency use a real jack. On-board jacks rarely have a very wide footprint. They can tip, and if they do they can bend or buckle very quickly. You can get a much safer jack at Wal-Mart or whatever for less than $50. I change my tires a lot, since I autocross my 8. I park the car on boards first, since my car is lowered. I lift the front by the subframe, in front of the oil pan. I lift the rear by the differential. If I'm going to work under the car, I put stands under it first. I like to use suspension or subframe mounting points; something very thick and solid. I know the car has jack points on the edges, between the wheels, but there's typically pretty thin metal there that gets bent easily. WTBRotary! 10-06-2008, 11:51 PM Personally, I wouldn't. Sure, the on-board jacks are fine in a pinch, but if it's not an emergency use a real jack. On-board jacks rarely have a very wide footprint. They can tip, and if they do they can bend or buckle very quickly. You can get a much safer jack at Wal-Mart or whatever for less than $50. I change my tires a lot, since I autocross my 8. I park the car on boards first, since my car is lowered. I lift the front by the subframe, in front of the oil pan. I lift the rear by the differential. If I'm going to work under the car, I put stands under it first. I like to use suspension or subframe mounting points; something very thick and solid. I know the car has jack points on the edges, between the wheels, but there's typically pretty thin metal there that gets bent easily. Still having a tad of trouble findings your spots pockets... do you mind taking some pics?:uhh: Guy Hollywood 10-07-2008, 08:29 AM Finding where to place the jack or the stands? Jon316G 10-07-2008, 08:39 AM I've had occasions where the floor jack wouldn't fit under the car and I used the car's scissor jack to get the car lifted until it was high enough for the floor jack. Then I kept the scissor jack lightly touching the jacking point on the side just as extra protection. Huey52 10-07-2008, 09:29 AM Page 7-13 in the '05 manual shows the sill jacking locations, "removing the tire." They're the standard "cut out" flange positions similar on most cars. One corner at a time and do use a jack stand after jacking for best safety. I personally use a lightweight low profile aluminum race jack but the onboard is adequate. WTBRotary! 10-07-2008, 09:15 PM Finding where to place the jack or the stands? i was hoping both... but i guess ill try to find it...:Eyecrazy: Jon316G 10-07-2008, 09:24 PM A simple search (hint hint) for "jack stand" gave me many threads... including one with this attachment: http://www.rx8club.com/attachment.php?attachmentid=122611&d=1214047137 |
