oil level question (newb)
Old Sep 29, 2008 | 05:14 PM
mlfarrell's Avatar
Okay so I know 2 add oil every two fillups and I've already picked which kind I'm gonna use so thats not a prob.
The question is, I'm currently at my first fill-up and my oil level is a litle below the full line (like maybe an 8th or so, maybe not even that much)
Should I wait til my next fill-up? The manual says I'm okay until it gets almost at half but I wouldn't ever let it get that low.
And I top it off until it gets right at that full line correct?
Old Sep 29, 2008 | 05:36 PM
dynamho's Avatar
You can wait till the next fill up or even the one after that.
Old Sep 29, 2008 | 05:40 PM
Marklar's Avatar
A little below full is just about right. You don't want too much. Don't even worry about it until it gets below half. When you top it off you want it just below the full line, probably about where it is now.
Old Sep 29, 2008 | 05:41 PM
invasion08's Avatar
Try to keep the oil level between the top line and top dot.
Old Sep 29, 2008 | 07:59 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah i usually let mine get down about half way or so (that's nearly a qt I believe) then fill it up unless i'm bored and feel like givin her some oil haha....you are fine where it is....also it is not bad to be A LITTLE overfull but I mean A LITTLE NOT A QT OR 2 OVER.... but i would keep away from it but if you do overfill don't come running on here saying "oh no my motor i put a little too much oil in it" this motor is not that sensitive about it.....
Old Sep 29, 2008 | 08:02 PM
Spinning Sushi's Avatar
I <3 Sushi
Originally Posted by Nubo
[|--------------------] 1.8 quarts low
[-|-------------------] 1.6 quarts low
[-----|---------------] 1 quart low
[------------|--------] 1/2 quart low
I hope this helps.
Old Sep 29, 2008 | 08:43 PM
YaXMaNGTO's Avatar
It's a Cavalier
Damn it. Just called Autozone. They're out of the 1.8 quart bottles of oil. What the hell am I supposed to do now?!!?!?!
mr. GrandGame
Sep 9, 2025 10:41 PM
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
RotaryRider
Jul 20, 2015 07:05 AM
vssystemluba
Jul 19, 2015 04:16 PM
