View Full Version : Cash Card Brochure
jtdwab
12-01-2003, 07:33 PM
Does anybody still have the brochure that came with the cash card. I want to check the balance and as I remember their is a websight that you can do that. Can somebody post that and what is needed to get the info (i.e. account number, vin, name, etc.)
thanks,
Magnesium
12-01-2003, 07:45 PM
http://www.encompass-select.com/customer.html
jtdwab
12-02-2003, 07:26 AM
Thanks,
The down side is that I only have 6.75 left. Now what am I going ot spend 6.75 on ???
8ZoomZoomZoom8
12-02-2003, 08:52 AM
Keychain? :D
8_wannabe
12-02-2003, 09:39 PM
So what did u get with the other $493.25? Can the card be used anywhere that takes AMEX? I just got mine today and I'm chomping at the bits.
jtdwab
12-03-2003, 07:37 PM
Yah you can use it most anywhere. The brochure said it probably wouldn't work for pay at the pump so I never tried. But I used it all over. Going out to dinner, buying groceries at wal-mart. Anywhere I needed to buy something. It was nice. I wish I had a couple hundred more of those cards. Won't have to spend any of my own money for months.
Magnesium
12-03-2003, 09:22 PM
I wouldn't use it at the pump either... The gas pumps pre-authorize anywhere from $30-$90. That is why they suggest that you don't use it for that.
I have $6.45 left on mine. I will go to the gas station and go inside and hand them the card, then I will pump exactly what is left and then throw it away.
RX8by
12-05-2003, 05:50 AM
You can just add more money to make up the difference. "Q: What if Cardholders want to buy an item that's higher-priced than their Card value?
A: You may typically supplement the purchase with cash, check, or credit card to purchase higher-priced rewards
harwax
12-05-2003, 06:26 AM
If I remember correctly the brochure states -if you use card at a resturant, they automatically add 20% as a tip.
jonalan
12-05-2003, 04:50 PM
Well, they don't add a 20% tip, they pre-authorize for a 20% tip; to make sure there are enough funds available for you to tip up to 20%.
And I did use it at a gas pump - once. It charged (pre-authorized) $90! Several days later the charge was corrected. I haven't used it at the pump since.
