Tire pressure question
Old Sep 22, 2008 | 11:44 PM
jsspss21's Avatar
I have an '04 RX-8 with a 6 speed, 225/45/18 tires. For everyday driving, what PSI do you keep your tires inflated to? The owner's manual says 32.
Your thoughts?
Old Sep 22, 2008 | 11:48 PM
ShinkaTeen's Avatar
space reserved for shirt
i do 32
Old Sep 23, 2008 | 04:11 PM
nuke0907's Avatar
Never Blend In
always use the pressure the owners manual tells you. it does not matter what tire size you have.
Old Sep 23, 2008 | 05:06 PM
NgoRX8's Avatar
32 is good for daily driving. that's what i use and i have aftermarket wheels and tires.
Old Sep 24, 2008 | 01:29 PM
hercmafia's Avatar
I keep mine at 32 as well, well I try the 2 nails make that a bit more difficult.
Old Sep 24, 2008 | 02:58 PM
EdwardsB's Avatar
Registered RX-8 User
depends on what you want to do/how you want the car to behave.
but for DD go with the 32 as stated
Old Sep 24, 2008 | 07:02 PM
ShellDude's Avatar
weeeeeeeeee
32 on a cool day otherwise you'll be greeted with a buzzer and TPMS light one cold morning... just happened to me the other day.
Old Sep 25, 2008 | 05:24 AM
yushinrt's Avatar
my one is at 28 do you think that is too low ?
Old Sep 25, 2008 | 07:51 AM
Huey52's Avatar
Registered Zoom Zoomer
Yep, I just cold inflation plussed mine up a bit in our now cooler weather. 32 psi for daily driver.
Higher than recommended air pressure gives a bit better gas mileage, but promotes uneven center-tread wear. Dangerous if very high - blowouts.
Lower then recommended promotes uneven edge-tread wear and is dangerous (potential tire unseating if very low).
28 psi is a bit low.
Remember to always check air pressure when tires are relatively cold (not run for a few hours) and in the ambient driving environment.
drebbrnator
Dec 27, 2018 07:02 PM
olivierapex
RX-8 Racing
12
Sep 4, 2015 12:14 PM
GracefulShanks
Aug 18, 2015 11:40 AM
MolecularConcept
Jul 26, 2015 09:09 PM
