What spare parts have you got on-hand?
Let's see who's got a big pile of extras in their garage. Don't post junk, worn-out stuff that's waiting to get sh*t-canned, but spare parts in good condition that could be used if needed. I'll start-off with my modest pile:
* Spare OEM hood (perfect condition)
* My OEM orange corner lenses (running clears now)
* 5 extra OEM 18" rims
* OEM front mask
* Extra yellow LED clusters for the clears
* Couple of sets of eyelids
* Spare spark plugs
* Stock gas cap (running a locking cap now)
* Extra set of BN, unused OEM floor mats
* Set of Mazda all-weather floor mats
* Extra set of 5 Mazda center caps for rims
* 4 Extra foam disks for cup holders
Watcha got layin' around?
Professional mechanics, suppliers, brokers & customizers, have the good taste to excuse yourself.
* OEM front mask
* Spare spark plugs
Last edited by Jethro Tull; Sep 21, 2008 at 10:11 PM. Reason: Forgot some high-dollar stuff..lol
Hmm
Probably a bunch more that I have forgotten about...
- MazdaSpeed front bumper
- OE Rear bumper
- OE Hood
- 2 transmissions (complete)
- 1 motor (complete)
- 3 intake manifolds
- 2 exhaust manifolds
- 16 fuel injectors
- 3 OMP
- 2 MAF
- OE Fuel Filler door
- OE CAT-back
- Set of OE springs and dampers
- 3 OE Intakes
- 2 OE Engine covers
- 8 OE Coils
- Alternator
- A/C compressor
- 2 PCMs
- 2 OE engine wiring harnesses
- OE floor mats
- OE front "bra"
In my house:
Spare tire, removed from car
Jack, removed from car
4 winter wheels/tires
Stock lid
Stock intake manifold
At my shop:
Complete stock transmission
Complete stock rear axle
Stock heads
Stock camshaft
Stock pushrods
Stock exhaust manifolds
Stock Y pipe
Stock catback
Stock Torque arm
Stock lower control arms
Soon:
Stock rear seats
2 stock wheels with drag tires
Edit: oops...forgot some.
Stock lid
At my shop:
Stock heads
Stock camshaft
Stock pushrods
Stock Y pipe
Stock catback
Stock Torque arm
Soon:
Stock rear seats
lol ok so....
Stock Wheels 18"
Front and rear Black seats
Front and rear Brown/black seats
Rear cloth seats ( two sets)
Black door panels ( set of 6)
Brown/black door panels (set of 6)
MT instrument cluster
Dash airbags (3)
Drivers Airbags (3)
Brown/black Steering Wheel
Black drivers front door
Black drivers rear door
Black pass. Rear door
Sunroof assymbly
Curtain airbags (8)
Airbag Control Unit (3)
Front Impact sensor (2)
Side impact sensor (7)
TPMS sensor x4
Stock airbox
Sport sway bars w/bushings
Bose Radio and face (2)
Bose amplifier (2)
Limited Slip Differential (2)
MT steering column (2)
MT power steering rack (2)
AT driveshaft
AT transmission
AT torque convrt. Assy.
MT driveshaft
MT flywheel and clutch assy.
Front subframe (subframe only) 2
Rear subframe (complete minus dr. axle)
Rear subframe (complete )
AT Power Plant frame
MT power plant frame
AT starter
Engine wiring harness
Engine bay wiring harness
AC condensor
Passenger Headlight
Engine Cover (2)
Nordic Green Spoiler
Fuel injectors and rail
AT ECU and PSCM
Sliding console lid (2)
Home link mirror
Rear console only (4)
Main console assy (2)
Exhaust manifold (3)
AT intake manifold
AT throttle body
Master cylinder and booster assy. (2)
Radiator fan assy. (2)
AT shifter assy.
Heater core (3)
Dash and support frame (2)
Ac lines and dash unit
Front Control arms (12)
Air pump (4)
AC compressor (3)
Emergency brake (2)
VFAD air hose (4)
Lower air divert tray (3)
Drivers mirror in WB
Front suspension ( 6 upper, 2 lower)
EGR valves and tubes (4)
E-brake cable systems both sides
Hood release cable
Emergency tire repair kit (2)
LCD radio display (4)
Steering hub assy. w/ switches (2)
Steering clockspring (2)
Mass airflow sensor (2)
Dome lights (4)
Dr. window switch panel (4)
Pass. Window sw. panel (4)
window motors (2)
keyless entry unit
Battery tray (2)
Wiper fluid bottles (4 black)
C-pillar trim (8)
spare tire mount bars (2)
interior wiring harness front and rear
Rear windows both sides
Strut Bars (2)
springs ( full set x2 )
Jack tray (3)
Upper trim in rear dash (2 sets)
Full set of hinges (hood, trunk, doors)
Wiper arms (3 sets)
Seatbelts (7 front, 6 rear)
set of door sills
Stock pulleys
oil cooler shrouds both sides
Trunk side carpet
trunk bottom carpet (2)
Trunklid insulation (2)
Hood Insulation
wiper cowl
gas cap assy.
hood and trunk latches (2 sets)
Trunk back panel (3)
Stock Wheels 18"
Dash airbags (3)
Drivers Airbags (3)
Sunroof assymbly
Curtain airbags (8)
TPMS sensor x4
Stock airbox
Bose amplifier (2)
AT driveshaft
AT transmission
MT driveshaft
AT starter
AC condensor
Passenger Headlight
Engine Cover (2)
AT ECU and PSCM
Home link mirror
AT intake manifold
AT throttle body
AT shifter assy.
Heater core (3)
Air pump (4)
AC compressor (3)
Emergency brake (2)
VFAD air hose (4)
Hood release cable
Dome lights (4)
window motors (2)
keyless entry unit
Battery tray (2)
C-pillar trim (8)
Strut Bars (2)
Jack tray (3)
Wiper arms (3 sets)
set of door sills
Stock pulleys
Trunk side carpet
Hood Insulation
wiper cowl
gas cap assy.
*2 OEM WB hoods
*1 Set of WB side aero flares
*1 Black OEM front bumper
*1 OEM cat. converter
*Stock panel intake and walls and screens
Cant think of anything else.
EDIT: LMAO at GR3DDY's post!
Originally Posted by MazdaManiac
Yeah, I guess I should have listed my FC, FD, Miata and MX-3 parts as well...
Stock intake air box
stock ront strut bar
stock springs
stock cat back exhaust
stock cat mid pipe
left head light assembly HID
stock corner marker lights
18" wheels and tires
4 tpms
new front slider console cover
spark plugs
exhaust manifold (at MM's)
Veilside side skirts
stock Ti gas door
"RX-8" license plate frame
stock engine cover
stock springs
stock cat mid pipe
4 tpms
spark plugs
stock Ti gas door
stock engine cover
