This normal?
Old Sep 21, 2008 | 03:07 PM
dugyrios's Avatar
This normal?
I just got a 2005 shinka about two days ago and I am still getting a hang of it. My question is since it is a rotary engine and Im not used to driving it yet, is it normal that my car stalls when the engine is cold; for example when i am sitting at a red light and I have been driving for about 5 minutes the car stalls, is this normal? and btw I live in florida its 98 degrees outside.
thank you
Old Sep 21, 2008 | 03:09 PM
invasion08's Avatar
No that is not normal. How many miles on it and what services have been done?
mysql's Avatar
Doppelgänger
not normal.
Old Sep 21, 2008 | 03:10 PM
mysql's Avatar
Doppelgänger
I also live in FL. It's only 90F outside.
Old Sep 21, 2008 | 03:17 PM
dshiznit1489's Avatar
Formerly Polak Graphics
Not normal at all. Get it check out ASAP before it floods!
Old Sep 21, 2008 | 03:24 PM
fahrfegneugen's Avatar
Wow that is way messed up.
Old Sep 21, 2008 | 03:27 PM
musclecarconvrt's Avatar
Check the coils. Electrics fail in the heat. Mine did. Cheap fix.
After that, seriously consider pre-mixing in high heat conditions. 3-4 oz per tank will do wonders.
Old Sep 21, 2008 | 03:51 PM
dugyrios's Avatar
this normal
It has 39k miles on it ,and the carfax is clean and it shows it was serviced regularly. Whats weird is that after ive been driving for a while and the engine warms up it stops? What could I do about this just take it to the mazda dealer? You think it may require a expensive repair? cause damn just got it and im pretty broke.
Old Sep 21, 2008 | 03:57 PM
invasion08's Avatar
Not that this is going to fix your problem but as the ECU been reflashed with MSP16
http://www.finishlineperformance.com...13-08-1925.pdf
This is a free reflash since its a recall not TSB
Old Sep 21, 2008 | 04:08 PM
DarkLord7854's Avatar
Software Engineer
Where in Florida?
Old Sep 21, 2008 | 04:17 PM
dugyrios's Avatar
this normal?
Bought it in west palm but I live in gainesville. My vin number is in the vehicle inspection range so now what do i do? write down the campaign number and call the mazda corporate dealer assistance? Is this a facotry problem that they fix.
Old Sep 21, 2008 | 05:00 PM
your car is still under its power-train warranty, you should be fine.
Old Sep 21, 2008 | 05:05 PM
invasion08's Avatar
No bring it in to the any mazda dealer and ask for it.
Old Sep 21, 2008 | 05:12 PM
well tell them what is wrong too
Old Sep 21, 2008 | 05:42 PM
dugyrios's Avatar
is the problem with my car a sign that it might need a tune up? I will take it to the mazda dealer and ask about the ECU issue
Old Sep 21, 2008 | 05:46 PM
04RX8man's Avatar
Rotary Powered Countryboy
Definately not normal I would take it to a dealer asap....
Old Sep 22, 2008 | 01:22 PM
dugyrios's Avatar
Someone told me to disconect the battery for a few minutes and I did that and it stop stalling on me. What was the problem?
Old Sep 22, 2008 | 01:26 PM
Jethro Tull's Avatar
Living In The Past
Is it a manual? Was the stock flywheel ever replaced with a lightweight flywheel?
Old Sep 22, 2008 | 01:30 PM
Today's cars do not need tune-ups because the car computers constantly do this while you drive. In a sense, they learn what the engine wants based on a set table of definitions and tries to make the car comply. If your car got better after disconnecting the battery for a while then your car had essentially learned the wrong thing somewhere. If someone monkied with the crank position sensor before you, then the car might have thought the rotors were in the wrong place and it would run like junk. Disconnecting the battery has the effect of making your car re-learn what it needs to do.
Old Sep 22, 2008 | 02:19 PM
nvrfalter's Avatar
tonybob failpants
do you let it warm up before you drive? you should.
Old Sep 22, 2008 | 02:27 PM
Shinka_MJR's Avatar
SHKWAV
your coils are covered by warranty. go to the dealer, tell them you are stalling when idle or stopped, etc. Ask them to check the coils and do a compression test. Don't give them any other option. You almost have to demand it be done or they won't go through the trouble.
Also as recommended, have them make sure the ECU has been reflashed. A new update was sent out in early `08.
Old Sep 22, 2008 | 02:44 PM
kersh4w's Avatar
Hit & Run Magnet
dont ask for compression test yet.
just get the msp16.
Old Sep 22, 2008 | 07:36 PM
dugyrios's Avatar
I went to the dealership they said they would do an inspection and update the computer on my car for no fee, thanks for your help ev
Old Sep 22, 2008 | 07:50 PM
Shinka_MJR's Avatar
SHKWAV
gosh that was sure generous of them... considering it's something they must do.
I took my car in last wednesday for an airbag light and squeaking brakes. I also have a `05 Shinka, roughly 43k now, got it just under 41. Anyway, i was suspicious of the coils from everything i've read about on here. So on a whim, i told the service dept that my car had mysteriously stalled 2x recently while sitting at a stop sign and in my driveway. They said they'd check it. Truthfully, i didn't have any issues at all that i could tell. The car started kind of hard but that was all and nothing really to go on about.
Turned out i actually had a bad coil afterall. All four got replaced under warranty.
Moral of the story, don't settle for anything less. If you think there's an issue, get that specific issue checked out. If you have to... exaggerate to get results, so be it.
Old Sep 22, 2008 | 08:17 PM
puch96's Avatar
I would have the dealer check all recalls that were performed on the car. If some are missing, they should perform them so you are up to date.
Then, have them check your coils and plugs. If that fails, they should check compresion...
