Fs Mtx Thunderlink Powered Sub Price Drop
Old Sep 15, 2008 | 07:02 PM
p-trix's Avatar
brand new sealed in box...better than basslink powered sub
$200 local
$230 shipped In US
Old Sep 16, 2008 | 01:27 AM
rx8speeddmon's Avatar
Location??
Old Sep 16, 2008 | 02:10 AM
p-trix's Avatar
valencia ca
Old Sep 16, 2008 | 05:40 AM
first-rotary04's Avatar
wankel? what's that?
hey,
is there a DIY installation for this??
if there is I might be interested.
do you have any other info ie. model, serie, and all that good stuff you can provide?? a link would help as well.
who did you buy it from?
thanks
Old Sep 16, 2008 | 12:11 PM
p-trix's Avatar
i do not have a diy...but here are specs and a pix
Want to add some big bass to your car? MTX offers a simple, straightforward answer to your needs: the X ThunderLink XT110P, a 10" powered subwoofer that'll deliver strong low-frequency output without hogging the room in your trunk or cargo area.
The durable enclosure houses a built-in amplifier that sends 100 watts to the 10" subwoofer, while an unpowered 10" passive radiator speaker cone adds extra bass response with reduced distortion. Shape the bass with convenient front-mounted controls for bass boost, volume, and crossover point. A wired remote lets you control the volume, crossover, and phase inversion from the driver's seat.
You can connect the X ThunderLink XT110P to almost any factory or aftermarket system, thanks to preamp- and speaker-level inputs. The included mounting brackets let you place the XT110P securely in the vertical or horizontal position. Add some fundamental fatness to your system with this versatile powered sub.
Details:
* compact powered subwoofer
* 10" woofer plus unpowered 10" passive radiator speaker cone
* built-in 100 watts RMS amplifier
* frequency response: 39-150 Hz
* variable low-pass crossover (30-150 Hz)
* variable phase control (0-180°)
* bass boost control (-3dB to +3dB)
* preamp- and speaker-level inputs (including harnesses)
* wired remote with volume, crossover, and phase inversion controls
* auto turn-on switch
* mounting brackets included
* 10-gauge power and ground leads recommended — wiring not included with system
* dimensions: 15-5/8"W x 12-1/8"H x 8-7/16"D
* warranty: 1 year
* Want more peace of mind? Extended Service Plans Available
Top of page
Jesus Martinez
44
May 6, 2025 08:09 AM
Billy Marcial
Mar 1, 2018 06:50 AM
ableobject
Mar 22, 2016 11:37 PM
GracefulShanks
Aug 18, 2015 11:40 AM
CMRine04
Jul 29, 2015 02:07 PM
