Anyone's Car Smell?
Old Sep 12, 2008 | 08:23 PM
Rotary Mike's Avatar
Registered 407 Abuser
Anyone's Car Smell?
My car always had a mild "Hot/Burning Grease" smell to it since I picked it up. I chalked it up to the fact that I just had the new engine installed and it was burning off the excess oils and grease.
Then I go ahead and change both my tranny fluid and rear diff fluid about a month ago (BTW - I have the 24mm and 23mm sockets if anyone wants to do this at a future install meet). While loosening the drain plug I dropped my ratched and hammer into the catch pan....spilling used tranny oil all over me and the underside of my car (like the exhaust).
Now if I cruise with the sunroof open, all I can smell is hot gear oil. It is wierd, I cannot smell it outside the car, only inside. The car has no leaks and the gear levels are still ok.
Anyone else have a car that smells?
Old Sep 12, 2008 | 08:51 PM
TheDopeShow's Avatar
theDopeShow
maybe its time to change your cabin air filter????
Old Sep 12, 2008 | 09:23 PM
Footman's Avatar
Dodging those Corollas
That's odd.. the Stanley socket wrench set I just bought has a 24mm, 22, 21, but now 20 or 23 mm???
It's not missing, the set is complete as it is, but those ones aren't there...
Old Sep 13, 2008 | 02:44 AM
TragicallyHip's Avatar
IfYerNotWasted..TheDayIs
I do... I can't quite pin-point what the smell is, but it's enough to give me a head-ache or make me nauseous...
Like yourself, I can't notice it outside of the car and I typically only smell it if I have my sunroof open...
Old Sep 13, 2008 | 04:00 AM
Spinning Sushi's Avatar
I <3 Sushi
The smell is seeping through the hole where the shifter goes through.
I have a similar problem... the only difference is that mine goes through the hole where the shifter goes in. It smells like socks because I'm running Redline Heavy Shockproof.
Old Sep 13, 2008 | 12:10 PM
When do you get your smell Renesis? At all times, or when the sunroof is open?
As long as I keep my windows up, sunroof closed and a/c on re-circulate, i never get the smell... But i've noticed that even raising the sunroof while leaving the sun-shade thing closed will bring the smell on... Would that cause a vacuum strong enough to bring the smell up through the shift-boot?
Old Sep 13, 2008 | 12:58 PM
DrewMan's Avatar
Culpam Poena Premit Comes
time to stop eating baked beans and fried eggs for brekkie
oh and get a vanilla magic tree
Old Sep 14, 2008 | 01:31 PM
Thanks for all the info guys. I'm happy to see that i'm not the only one with this problem. I can live with the smelll, I'll just go buy an air freshener.
Old Sep 14, 2008 | 01:44 PM
dmak_el's Avatar
i think the best way is to get under the car, and just wash the transmission really good.
I think with the sunroof open, it just help suck the air up from inside the car, that's y the smell is stronger.
Old Sep 15, 2008 | 08:16 AM
rotten42's Avatar
Mentalhealth is overrated
I had this problem with my car to after I got the second engine change. The stealership tried to tell me that it was maybe some oil in the engine compartment left from the change. The smell never went away. I took it in on 4 different occasions over the course of 1.5 years. The last two times they said they couldn't recreate the smell. A bunch of bullshit!!! They never did find outr what the problem was.
Skyl3r
Dec 2, 2019 04:51 PM
Quato_jr
Aug 4, 2015 09:22 AM
marc2820
Jul 26, 2015 10:47 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Bamaham
Jul 23, 2015 08:08 AM
