Transmission 2nd gear grind.
Old Sep 3, 2008 | 09:23 PM
RawrX8's Avatar
Grocery Getter
When I shift above 7.5k+ rpm smooth shifting. Not slamming gears like a arcade game. It will not shift into 2nd shift without grinding. Below 7k it will transition smoothly. Fluid levels are still acceptable. Same fluid as from the dealership. 13k miles on it.
I do drive the car like I stole it every day. I can honestly say I have grinded 2nd maybe 3-5 times by accident strolling around town. But I dont speed shift or slam gears. Used to driving DSMs with their glass cannon transmissions.
Syncos dead? Want some opinion and feedback before I drop it off and they say "Sorry, you raced your car, not covered!"
Old Sep 3, 2008 | 09:37 PM
WVBoosted8's Avatar
I dont know if it had anything to do with it..... but.... Mine did the same thing when the clutch was about gone. GL
Old Sep 4, 2008 | 11:39 PM
either your synchro and/or mating slider are boffed or possibly the shift fork is bent, a bad/failing/worn clutch would typically cause problems in all gears, not just one ...
Old Nov 24, 2009 | 11:06 PM
Spirograph's Avatar
I have an '04 w/ 43k that just started to grind in 2nd. It'll grind just upshifting into it at low rpms, and the clutch is depressed to the floor. I just swapped the fluid for 2/3 Amsoil MTL 75-90, and 1/3 Amsoil MTF Synchromesh. So far, no grinding in the past few days. But, I'm sure the damage is already done. My question is, I know that the MTF synchromesh 10w30 is too light for the 8's transmission to use in full, but will the MTF blend help to protect the synchro and mating slider?
Also, if I track with this blend, which part of the transmission is going to wear harshly?
Old Nov 25, 2009 | 12:17 PM
VERSUS4582's Avatar
I had the same problem...Try RED LINE HEAVY SHOCKPROOF GEAR OIL ...It helped me very much..Just give it some time to warm up and you will see huge difference..Trust me on that
Old Nov 25, 2009 | 09:52 PM
Spirograph's Avatar
I read in some threads that the shockproof is bad, in the long term it will damage the transmission. Though I can't remember how or why. I know mixing in Amsoil MTF Synchromesh like I'm doing now is questionable too, especially if you drive like I do.
Old Nov 25, 2009 | 10:09 PM
toneskii707's Avatar
suck my smog
Use redline MT-90 that's what I use. I have a 04 with 68xxx miles and it grinds going to 2nd and going into 4th changed to MT-90 and its huge difference.
Old Nov 26, 2009 | 05:31 AM
VERSUS4582's Avatar
I have used MT90 and is not anywhere near the redline shockproof gear oil..I had a major problem so i went through alot of oils..This is the best so far by far!!!!
Old Nov 26, 2009 | 11:02 AM
Charles R. Hill's Avatar
Owner of BHR
It isn't the fluid..........
Old Nov 26, 2009 | 12:03 PM
scremn8's Avatar
the more things change
^^^ time for a new trans.
or rebuilt
Old Dec 2, 2009 | 09:07 PM
JantzenRX-8's Avatar
Don't do this...
Old Dec 2, 2009 | 09:13 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I wonder why stuff like this cant be in just one thread.
Common problem. (happened to me) VERY often blamed on syncros, mistakenly imo. I think it gets blamed on syncros cuz that is the only think most folks know the word for in a transmission that has to do with switching gears.
Fluid will not help.
Listen to Team and Charles.
Old Dec 3, 2009 | 03:53 AM
kdoiron08's Avatar
mine grinds below 7k, it was slave cylinder goin out.. dnt do wat i did and dnt fix, my syncros r bad, and dealer wnt cover it
Old Dec 3, 2009 | 04:15 AM
VERSUS4582's Avatar
Originally Posted by JantzenRX-8
Don't do this...
Don't do what ???
That oil helped me a lot..Believe it or not i dont care..
Old Dec 3, 2009 | 05:53 AM
kdoiron08's Avatar
dnt keep driving it witout fixing 80 dollars turned into 3.5K i tried the oil. royal purple..it was da most expensive, ddnt help..
Old Dec 3, 2009 | 08:54 AM
Owner of BHR
So does a MaxiPad on a gunshot wound. RedLine gear oil is good stuff but that isn't the problem.
Old Dec 4, 2009 | 04:07 AM
you know the level is good how?
skip all the what aftermarket fluid will make it work..
Old Dec 4, 2009 | 06:56 AM
Well some people do seem to resolve the issue with an oil change
Since it's cheap enough to try (2 qts) it's worth a shot before spending the big money on a trans R&R
but the wrong oil choice will be worse still and every recommendation under the sun is being made
I'd stick to the Redline products, try MT90 first, then Heavy Shockproof as maybe a last ditch effort as it's a racing fluid intended to be changed regularly, not intended as a high mileage daily use oil
Old Feb 10, 2010 | 02:30 PM
josuar88's Avatar
The Crawlster
Ok now I'm having a similar problem changed the oil less than 5k ago and well now 2nd will occasionally grind when rev matching and down shifting. Today was the worst one yet big old crunch. Now what do you have to show the dealer when you go to get it looked at and does anyone around my area know of a good place to get it looked at. I don't have the receipts to my last oil change for the transmission. So what do I do essentially.
Old Feb 11, 2010 | 12:11 PM
813KR$'s Avatar
I have had these grinding issues ever since I got my car with 55,000 miles on it. Tried multiple royal purple/redline/mobil1 oils. Nothing helped and some actually made it worse. The best thing that worked for me is a full fill of lucas oil. thick ****! WORKS GREAT!
152,000 miles and counting!
Its like night and day difference! Rarely grinds now, except for when the trans is not warmed up yet.
Anyone have any experiences with lucas?
Old Feb 11, 2010 | 03:57 PM
Only marketing and replies from Racers.
I have used their fuel injector cleaner with success.
Old Feb 14, 2010 | 04:58 PM
helfish's Avatar
Kiazer
NV
Try a braided line, that may help.
Old Feb 14, 2010 | 05:03 PM
evolvnola's Avatar
i have the same problem. i took it to the dealer to get a new clutch and the trans looked at. i got the clutch master and slave changed out and still have the problem
WTBRotary!'s Avatar
Drummond Built
Its the Transmission, from what ive read its a known problem. I myself have driven my friends 8 and have done perfect rev-matches and still grinded... New oil will help a little but wont fix the problem
Old Feb 19, 2010 | 11:26 AM
813KR$'s Avatar
%100 LUCAS OIL FIXES THE **** TRANSMISSION GRINDS ! ! !
as if I didnt say this earlier in this thread . . .
