I found the Bass rattle, but i need help
Old Aug 31, 2008 | 07:59 PM
ivory8's Avatar
Vegas rx8!
hey guys. I am having rattle issues. I just recently got 2 12" subs in my car, they sound awesome but i am having a terrible rattle. Its very loud and can be heard even with the volume being on 25. Sorry for the terrible quality picture. but ill try and be as clear as possible.
the car has huge amounts of dynamat, this is the only area on the whole car that rattles. If i apply pressure to the noted areas i can almost completely eliminate the rattle
The panels marked with a (red) dot, are the loose panels. And the rattle (contact point) is marked in lime green.
I was thinking maybe some weather stripping would fix my problem but i'm not sure.
any help would be greatly appreciated.
Old Aug 31, 2008 | 08:38 PM
Socket7's Avatar
ಠ_ಠ
I've got a few rattles there myself. I was planning on using a few pieces of double sided tape.
Old Sep 1, 2008 | 02:12 PM
ivory8's Avatar
Vegas rx8!
anyone know of a solution???
anyone??
Old Sep 1, 2008 | 10:14 PM
firebirdude's Avatar
User and Abuser
Same problem in the same area for me. Mine's not nearly THAT bad though.
Anything that prevents the offending panels from touching each other will cure the noise. Obviously. Be it cardboard, weather stripping, tape, etc.
Old Sep 1, 2008 | 10:38 PM
G3tR3DDY2GR3DDY's Avatar
ill go take mine apart tomorrow and do some research and solution if someone wants to message me and remind me around noon?
Old Sep 2, 2008 | 12:15 AM
ivory8's Avatar
Vegas rx8!
ill be in school but ill try my best :D
Old Sep 2, 2008 | 02:35 AM
DrewMan's Avatar
Culpam Poena Premit Comes
double sided tape and some rubber strips will fix that bugger right up
Old Sep 2, 2008 | 05:21 PM
ivory8's Avatar
Vegas rx8!
^---ill give it a try later this week when i have time. this was as soon as i could get on but just givin getready a reminder.
Old Sep 3, 2008 | 12:01 AM
ivory8's Avatar
Vegas rx8!
after rollin around with the windows down i found that the rattle from that portion of the car was significantly less when the windows were rolled down. maybe it has to do with the air pressure or something but it's just something i noticed. but like i said, i'll go to lowes this week some time and get some weather stripping of some kind. maybe make a DIY.
Old Sep 3, 2008 | 02:23 AM
rollerbldes's Avatar
Did you try taking off the plastic cover for the trunk light bulb?
Old Sep 4, 2008 | 08:22 PM
jstkilntim's Avatar
resU deretsigeR
Make sure all of your metal clips are installed on those panels. Check the white plastic pieces that the rear seats slip in to. Use dampening material to fill any gaps instead of 2 sided tape.
Old Sep 5, 2008 | 12:31 AM
ivory8's Avatar
Vegas rx8!
yes, yes i did. I got rid of that about 3 weeks ago. That helped the rattle a lot but it still rattled quite a bit afterwards. Again, I have been terribly busy this week, but come this weekend ill do my best to get some weather stripping in there and investigate the rattle a bit more.
Old Sep 5, 2008 | 01:50 AM
Nubo's Avatar
Lubricious
This could be your rattling bass problem:
http://www.youtube.com/watch?v=VveIve2pRBk
Old Sep 5, 2008 | 07:38 AM
User and Abuser
I doubt that's it....
maybe...
Old Sep 5, 2008 | 05:10 PM
ivory8's Avatar
Vegas rx8!
omg, i forgot to grab my fish on a plack out of the trunk! doh! ill have to get that out of there :P
Old Sep 5, 2008 | 07:42 PM
User and Abuser
It could be this too...
http://www.youtube.com/watch?v=eBGIQ7ZuuiU
Old Sep 25, 2008 | 03:59 PM
arrexate's Avatar
The reason you notice less rattle (and I'm assuming a bit more bass) with the windows down as opposed to up is a phenomenon called the Helmholtz effect. Essentially, when you roll a window or a number of windows down in the car, you are creating an extremely large band pass enclosure with the windows as the vents. When this occurs you will notice higher levels of spl and being able to actually hear more bass due to the wavelengths completing closer to you're ears.
Happy hunting on the rattles, whenever I have a car come in the bay with an issue as extreme as the one you're having, I specifically isolate the offending clips with a wee piece of dynamat then actually mat the offending panel itself.
Old Sep 26, 2008 | 12:21 AM
ivory8's Avatar
Vegas rx8!
thanks for the info arrexate!
k well I JUST DID THIS TODAY. zero rattle after i fixed it, I finally fully enjoyed my bass.
all u need is 1 razor blade, a 3/4 inch cylindrical tube of foam weather stripping stuff.
i found it at lowes for 3 bucks. K and its extremely simple...
the space right below the black stripping of your rear window is in contact with your speaker panels back there. if u stick your finger in between the window and the plastic covers, with some pressure, u will find that your finger squeezes into that gap. Basically just take your tubing, cut it to size...and run it from the left side of the window all the way to the right side. just stuff the foam rope in there, it will be tough but that is ok. that tightness eliminates the rattle.
I will do a more comprehensive DIY later in time with pictures and stuff. i have a car show tomorrow so it wont happen then. but ill get it done in time... i hope this helps and its not too awkward sounding.
Old Sep 27, 2008 | 03:34 PM
Renesis07's Avatar
Vtak just kicked in yo!!
I might do this, mine rattles there also.
Old Sep 27, 2008 | 09:11 PM
ivory8's Avatar
Vegas rx8!
note to self: the foam shrinks under summer heat. im gonna have to re-apply it , or add more. ill see what i can do.
cliffkemp
Dec 24, 2024 10:48 AM
bosstin87
Oct 5, 2015 06:52 AM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
