What are these connections
Old Aug 31, 2008 | 06:13 AM
Glockperfection's Avatar
https://www.rx8club.com/attachments/series-i-do-yourself-forum-73/118744d1207802756-diy-mazda-zoom-power-engine-cleaner-engine-cleaning-seaform-clean3.jpg
Can someone tell me what these connectors do. I did the zoom zoom engine clean today and forgot to plug them back in after I went for a drive. The car wouldn't hold idle but I managed to drive it for about 5 miles by giving it gas right after starting the engine. I finally remembered that I didn't plug those plugs in. After plugging them in, the car held idle. I'm wondering if I did any damage to the engine.
Old Aug 31, 2008 | 07:15 AM
*sigh*
It doesnt matter, those are just secondary air injection pump stuff. U can even leave it alone and it wouldn't matter ONE bit
Reason why your car wont hold idle is Your ECU is re-learning the air volume.
Old Aug 31, 2008 | 07:22 AM
StealthTL's Avatar
Metatron
The one on the left, as NY says, is air injection - but the one on the right, IIRC, is the barometric pressure sensor, and quite important for mixture calculations.
S
Old Aug 31, 2008 | 07:24 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yeah, but shouldn't hurt the car if run without for a liitle while.
Now since plugged back in, everything will re-calibrate after a drive cycle or two right?
Old Aug 31, 2008 | 07:27 AM
Everything should be done in 3 "complete" drive cycle.
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Nov 24, 2015 01:00 AM
archon
Oct 1, 2015 06:08 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
