FS: NIB Sony DVX-100 DVD Changer
I have a new-in-box Sony DVX-100 DVD Changer for sale that I am asking $375 for (which is less than I paid). The only pieces that show any sort of wear are the mounting brackets because I had this mounted in my trunk for a few months. I never bought the necessary parts to run this through my nav screen so the unit has never been connected to a power source. There is absolutely nothing wrong with this changer, I am simply selling it because I bought a house and now have bigger priorities than the car at this point
If you have any questions please ask..... here are the specs and pictures....
Add-on (FM-style) 10-disc DVD/CD changer
Plays audio CDs, video CDs, DVDs, CD-Rs, and CD-RWs
Includes an outboard FM modulator which converts the audio signal to FM, then sends it through your receiver's antenna input
Transmitting Frequencies: The FM modulator allows you to select one of two transmitting frequencies, 88.3 MHz or 88.9 MHz.
PBC Functions: During playback of a PBC compatible Video CD, the PBC functions are automatically activated and you can display the PBC menu.
Disc List: You can display a list of discs contained in the magazine to check disc types, select a disc, or set the disc type for current playback.
Searching Methods: When playing a DVD or Video CD, you can quickly locate a desired point by specifying the title, chapter, or track, or by entering the elapsed time of playback.
Resume Play: This feature allows you to resume playback of a DVD, Video CD, or audio CD from where you last stopped, even if you turn the power off. Resume Play is deactivated if you press stop twice or the magazine is ejected.
Slow Motion: When playing a DVD or Video CD, you may move forward or backward through the program being played in one of the following slow motion speeds: 1/2, 1/4, 1/8, or 1/16 the normal speed.
Multi-Angle Display: This function allows you to choose the viewing angle of scenes that were shot from a number of different angles. Note: This function is limited to DVDs recorded with multiple camera angles.
Repeat Play: "A-B Repeat" allows you to select any portion of a title or track and play that portion repeatedly. When playing a DVD, you can repeat the current title or the current chapter. When playing a Video CD or an audio CD, you can repeat the current track or the entire disc.
Shuffle Play: When playing an audio CD, you can play the tracks on the disc in random order.
Intro Scan Play: When playing an audio CD, you can play the first 10 seconds of each track.
Program Play: Up to 20 tracks on an audio CD can be programmed and played in any order.
Audio Output: When playing a Video CD or an audio CD, you can choose one of the following audio output methods: Stereo ("Audio L/R"), Monaural Right ("Audio R/R"), or Monaural Left ("Audio L/L").
Aspect Ratio: You can choose a 4:3 Letter Box, 4:3 Pan & Scan, or 16:9 aspect ratio.
Parental Control: This unit allows you to set playback restrictions for DVDs using Parental Control. Parental Control allows you to restrict playback according to a predetermined level. You can select a parental control rating from 0-8, which is protected by a 4-digit password.
On-screen Display Language: The on-screen display language can be set to English or Japanese.
Wired and Wireless Remotes: System commands are made with the included wired remote control/display unit or wireless remote.
Optical Digital Output: The DVX-100 has an optical digital output that can be linked to a DTS/Dolby Digital processor.
Analog Outputs: The DVX-100 has one set of RCA audio outputs that can be connected to any receiver with auxiliary inputs. Two RCA composite video outputs (front and rear) are provided for connection to separate monitors.
Mounting: This unit may be installed vertically, horizontally, or at a 45 degree angle.
Dimensions: 10"W x 3 1/4"H x 8 1/8"D
If you have any questions please ask..... here are the specs and pictures....Add-on (FM-style) 10-disc DVD/CD changer
hey man- whats up? first time i seen you post here in a while. You still coming to BOTD this year right? Ill be back from the dead
how big is this? can it fit in the passthrough maybe? or possibly in that cargo tray box if you know what i mean? hit me up
Yep....I'll be there. I've not been as active lately due to a new house....but I still try to keep up with what's goin on. Anyway....the dimensions of this thing are pretty much the same as a standard cd changer.... 10"W x 3 1/4"H x 8 1/8"D....... so I'm not sure how you would mount it in the pass through but it's definitely shallow enough to fit in the cargo tray. Let me know if you want it or know someone else that might.
Chapsy
Sep 22, 2015 09:57 AM
04MazdaMan
Jul 15, 2015 08:23 PM
