RX8 Engine Rotors into 13b-REW??
Old Aug 29, 2008 | 06:55 AM
chironwsc's Avatar
Hi Guys
I am hoping some one on the forum can help me.
I would like to know if the RX8 engine rotors are the same dimensions as the 13b-REW RX7 rotors. In other words would a RX8 rotor fit in a 13b-REW engine? We are building a non turbo 13b and want to raise the compression ratio and also the lighter weight of RX8 rotors would help alot also.
Hope some one can help.
Regards
Henry
Old Aug 29, 2008 | 07:17 AM
Mazmart's Avatar
Well Henry,
You've come to the right place. We use these in similar fashion to what you're describing. They are slightly lighter than the FD's original rotors. You must use the cut-off seals or you will lose hp. You must cut the apex grooves deeper or you may break and lose a seal. The front is generally exchanged for the rear to take advantage of the fly cuts in the sides of the rotor for increased intake port timing.
Hope that helps.
Paul.
Old Aug 29, 2008 | 06:07 PM
Falken's Avatar
Drop it into 3rd
Just out of curiosity, what port type are you using?
Old Aug 30, 2008 | 02:37 AM
chironwsc's Avatar
Thanks for the replies.
The engine will have peripheral ports its a race engine.
I have been doing abit more research since i posted. I have read that its possible to machine the seal grooves to suit older rotor seals. Any thoughts on this and which seals would be best suited? Because the engine is for racing it will mainly run between 5000rpm and 9000prm most of the time.
Henry
F51
Aug 2, 2021 04:07 AM
vapor2
Nov 3, 2020 03:38 PM
dbarber
Jul 25, 2015 01:34 PM
Bamaham
Jul 23, 2015 08:08 AM
Belalnabi
Jul 17, 2015 07:48 PM
