Where does the front tweeters split off?
Old Aug 27, 2008 | 12:59 AM
rollerbldes's Avatar
Where does the front L/R output from the harness get split off to midrange / tweeter? The harness only has a L/R output, but no separate tweeter output. So it must get split somewhere.
Also.. does a crossover exist when it is split? I'm so confused.
Old Aug 27, 2008 | 09:46 AM
firebirdude's Avatar
User and Abuser
Inside the door panel. There is a unit with similar shape and size to an aftermarket component crossover.
Old Aug 27, 2008 | 11:57 AM
Even in the non-bose unit? I didn't see it. =/
Old Aug 27, 2008 | 12:45 PM
User and Abuser
Didn't know you were referring to a non-Bose 8. I can only guess the same spot. I would edit your original post to include the non-Bose information.
Old Sep 4, 2008 | 08:31 PM
jstkilntim's Avatar
resU deretsigeR
I have (had) Bose, but I know for a fact the front door speaker & front tweeter are wired in parallel straight from the HU. I imagine if you take off the door panel and check the wiring, it will be obvious.
Old Sep 4, 2008 | 08:34 PM
Makes it simple if they're wired in strait parallel. Maybe the stock HU setup has no sort of crossover whatsoever for the front doors. That works. I herd some car companies put a in-line capacitor as a simple crossover.
Old Sep 4, 2008 | 08:56 PM
User and Abuser
You mean every company with crossover goals in mind?
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
thewatcher101
Sep 18, 2015 01:48 PM
stickmantijuana
Sep 4, 2015 10:31 PM
