need a new front o2 sensor which one do i get?
Old Aug 25, 2008 | 05:45 PM
Mr.&Mrs.Magic's Avatar
I have a CEL p0031 and I've been told I need a new o2 sensor but which one do I get. I've only found 2 types the bosch ($363.95) and Walker($153.30). Why the huge price differance in the 2 their both wide band right?
Old Aug 25, 2008 | 07:55 PM
might look them up on
onlinemazdaparts.com
it will save you money..
Old Sep 14, 2008 | 11:22 PM
BoosTED's Avatar
I just noticed this as well.
Online Mazdaparts has the OEM O2 sensor for in between the two.
A good source for 02 sensors is www.oxygensensors.com they have the Walker for 123 OEM replacement.
The Bosch is needed for some fuel management applications. Not sure if this applies to the 8.
I am going to contact the reps that sell Walker and Denso to see what they say.
Old Sep 15, 2008 | 06:52 PM
813KR$'s Avatar
I got the denso 4 wire universal off ebay for like $50 for both. The front is a heated sensor. dont ask me what that means, but thats what I found out. My cel is still on, but havent scanned to see what the code is, my gas mileage is back to normal and idle is steady like it should be. Before I changed out the sensors I was gettin terrible mpg's (230 miles a tank, now upto about 300)and idle was not steady. I could feel more power in the lower rpm range after the new sensors. I got the sensors that can be used for the front and rear.
IF YOUR DOING THIS YOURSELF REMEMBER TO ALLOW TO COOL THEN SPRAY WITH PB BLASTER AND LET STAND FOR ABOUT 10 MIN AND THE SENSORS WILL COME OUT VERY EASILY.
BRAND NEW DENSO OXYGEN SENSOR!
UNIVERSAL 4 WIRE
SENSOR COMES READY TO INSTALL WITH SPLICING TERMINALS (SEE PICTURE). NO NEED TO PURCHASE ANY ADDITIONAL ITEMS. THIS MAKES INSTALLATION VERY QUICK AND EASY.
THIS SENSOR WILL FIT THE FOLLOWING VEHICLES:
YEAR
MAKE
MODEL
ENGINE
# OF WIRES
POSITION
2005
MAZDA
RX-8
R2 1.3L
FRONT & REAR
2004
MAZDA
RX-8
R2 1.3L
FRONT & REAR
LINK:
http://cgi.ebay.com/ebaymotors/NEW-D...spagenameZWD1V
Old Sep 15, 2008 | 07:41 PM
update: got the o2 from onlinemazdaparts and installed about 2 weeks ago. was a snap to do the easiest thing thus far.
Old Sep 16, 2008 | 08:44 AM
deputydog's Avatar
Yet another noob
DId you go with the oe sensor or the walker?
Old Sep 16, 2008 | 08:55 AM
OEM-bosch i think
Old Sep 16, 2008 | 10:29 AM
olddragger's Avatar
the front one is a wideband and the rear one is not--make sure you get a true wideband sensor for the front.
olddragger
Old Sep 17, 2008 | 12:29 AM
BoosTED's Avatar
I just ordered a set of the Denso
813KR$ did you reset the ECU after you installed the sensors?
The picture in the listing looks like the wideband sensor.
If they do not match I will have extra narrow band sensors.
OEM is Denso
Bosch does make a Wideband for the 8 as well.
The reps from www.oxygensensors.com have not responded as of yet.
Old Sep 17, 2008 | 12:46 AM
correct,
and both the sensors you mentioned above are oem, and less money than you were going to spend aftermarket.
Old Sep 17, 2008 | 06:03 AM
no ecu reset after install cel went was gone as soon as I started the car. I did however have some weirdness from the AP before the fix though???
Old Sep 17, 2008 | 08:58 PM
813KR$'s Avatar
yea, reset.
I need to scan for a code.
you kno if a cel is thrown for old spark plugs?
Do you kno where to hook up a scanner?
tjohnmeyer
Sep 28, 2017 05:03 PM
drlubell
Sep 26, 2015 11:58 PM
Forevermore
Sep 20, 2015 01:04 PM
yankeepicker
Sep 11, 2015 05:42 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
