vibration while driving above 50mph
Old Aug 21, 2008 | 08:21 PM
peanutbuster85's Avatar
I have a 04 Rx-8 that when you drive faster than 50mph it starts shimming in the front end area. I have had several opinions and still no luck on fixing the problems. I have replaced the wheels and tires. They were spun and balanced twice to make sure and all is good. Alignment was done and all was good. Visually everything looks in good condition. any ideas let me know.....
Old Aug 21, 2008 | 08:33 PM
Jon316G's Avatar
Grasshopper
I've never experienced a bad motor mount personally, but going over 50MPH you might notice bad motor mounts more than at slower speeds. Might be a place to check next.
Maybe someone who has encountered this can chime in to clarify my assumption.
But you performed all the basic steps that I would suggest doing....
Old Aug 21, 2008 | 09:14 PM
invasion08's Avatar
Check the endlinks
Old Aug 21, 2008 | 11:01 PM
philsbluerx8's Avatar
endlinks on the sway bar??? it wont even do anything if u drive on a smooth road without corning
Old Aug 21, 2008 | 11:04 PM
i think it should be an engine mount;
Old Aug 23, 2008 | 07:20 PM
thanks for suggestions, you think it may be the shocks getting worn out??
xAgyex
Jun 3, 2026 03:47 PM
ironj221
36
Jan 20, 2026 08:28 PM
ktec
Jun 26, 2021 10:18 AM
GrAfiX
Aug 24, 2015 08:08 AM
R2D2X8
Aug 17, 2015 08:47 AM
