Installed Cat Back Exhaust and now I have a check engine light????
Old Aug 20, 2008 | 06:40 PM
white311's Avatar
9K Smokin!
I had a shop install a borla cat back and had no problems for a week. I have only driven it twice since then and it has been fine. I got into it today and I have a check engine light on. What are some possibilities for this? I am assuming an O2 sensor issue, but I could be wrong.
Old Aug 20, 2008 | 07:27 PM
Jon316G's Avatar
Grasshopper
The cat-back shouldn't have thrown a CEL.
Take it to Autozone and get the code pulled.
Old Aug 20, 2008 | 08:56 PM
laythor's Avatar
I zoom therefore I am.
check your gas cap, it's not on tight.
Old Aug 20, 2008 | 09:02 PM
white311's Avatar
9K Smokin!
for real......the gas cap...if thats it i will kick myself in the nuts....i will go check it now
Old Aug 20, 2008 | 09:26 PM
can't be the gas cap. could be the gas cap.
you can go to an Autozone and have them pull the code to be sure...
Old Aug 20, 2008 | 09:36 PM
Jon316G's Avatar
Grasshopper
I think you meant to say, "can't be the CAT BACK. could be the gas cap."
Or were you playing Jedi mind tricks again.
EDIT: If you got the CEL as soon as you started the car, its the gas cap.
Just give the gas cap a couple more turns and allow a few drive cycles to clear the CEL.
Old Aug 20, 2008 | 09:38 PM
05rex8's Avatar
sold the 8... :(
say what?
Old Aug 20, 2008 | 10:10 PM
white311's Avatar
9K Smokin!
not the gas cap
Old Aug 20, 2008 | 10:11 PM
NgoRX8's Avatar
could be the gas cap. lol
happened to me.....
Old Aug 20, 2008 | 10:12 PM
Just re-set the ECU
If it comes back you have a problem.
Old Aug 20, 2008 | 10:14 PM
Jon316G's Avatar
Grasshopper
Originally Posted by Razz1
Just re-set the ECU
Last time I encountered the gas cap CEL I couldn't clear it with the odometer and brake pedal dance reset.
I had to wait for a couple drive cycle to let it clear itself.
Old Aug 20, 2008 | 10:30 PM
white311's Avatar
9K Smokin!
thanks for the input.....i guess i will wait and see after a few drive cycles. if that doesnt work i will reset the ECU
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
netrovers
Jul 20, 2015 03:32 AM
