Coil Replacement Inquiry
Old Aug 19, 2008 | 04:05 PM
mlee1978's Avatar
Hi,
Where can I buy coils for 04 RX8?
Can you also tell me the site with coil replacement instruction?
Thanks,
Old Aug 19, 2008 | 04:08 PM
alnielsen's Avatar
This site has 2 vendors that will sell you oem coils.
Med Center Mazda &
Onlinemazdaparts.com
They sell for between $25 & $30. Dealer list is around $85.
Old Aug 19, 2008 | 04:12 PM
mlee: welcome to the cult!!! errr.... "club"
Try sending a Private Message to Charles R. Hill, he is a forum vendor and might have ignition coils at a great price.
As for installation instructions, it's pretty straight forward.
Pop the hood, remove the engine cover.
See where the spark plug wires are? Well, the little black pieces they connect to are the ignition coils.
when you receive your new coils (4), simply replace them one at a time. They are universal so any coil can go in any spot.
You'll need a ratchet, extension, and I think it might be a 10mm socket. (could be wrong on the socket size)
-Loosen the spark plug wire
- use ratchet to loosen bolt
- remove coil
- insert new coil.
Do this one at a time so you don't plug the spark plug wire into the wrong coil.
Old Aug 19, 2008 | 04:18 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
^^^ listen to Jedi54, he's one of the good guys around here and speaks the truth.
Touche'
Old Aug 19, 2008 | 05:31 PM
mlee1978's Avatar
Thank you all your help.
Do I need to take out air filter or something? If so, how can I take it out?
And I would like to change spark plugs but don't really know where to get'em either.
Can you guys help me out on that?
Old Aug 19, 2008 | 05:32 PM
cjkim's Avatar
^noob
check the diy section. all questions answered there
Old Aug 19, 2008 | 05:35 PM
hey mlee:
You might need to take off the rubber accordian piece on your intake. It should have some clamps on it that you can loosen with a screwdriver or it might be an allen key. It might make it easier to get to the coils.
As for the spark plugs. Check with some of our vendors to see if they have any in stock. Do not use any other type of plug, the OEM ones are the ideal solution for your car.
Also, there is a Do It Yourself subforum that has a thread dedicated to replacing the spark plugs. Take a look there or use the search button towards the top right to locate the thread.
Old Aug 20, 2008 | 07:56 AM
S1lveRx8's Avatar
9K RPM's = ♥♥
- remove coil
- insert new coil.
hey mlee:
The force has spoken.
Old Aug 20, 2008 | 08:15 AM
be careful pulling the hose fittings loose from the rubber intake accordian, they get brittle with time and can break
smear a light coating of grease on the fitting end before re-installing them into the rubber accordian, they will then slide out/in much easier in the future
Old Aug 20, 2008 | 11:38 AM
S1lveRx8's Avatar
9K RPM's = ♥♥
RE7s and RE9s, $80/set (shipped) from BHR.
What's RE7 and RE9s? Me = Newb
Old Sep 30, 2008 | 09:11 PM
laythor's Avatar
I zoom therefore I am.
5k more miles before my BHR coil + plug order... let the countdown begin!
19k miles in almost 2 years... must drive more!
Old Sep 30, 2008 | 09:16 PM
alnielsen's Avatar
Originally Posted by sfsoldier14
when you buy the coils do you get all four for 27 or do you have to buy 4 sets for 27 each?
For that price it would be each.
delicious_dallan
Jan 17, 2020 09:17 AM
drebbrnator
Dec 27, 2018 07:02 PM
PotatoCannon
Sep 6, 2015 11:48 AM
GracefulShanks
Aug 18, 2015 11:40 AM
dbarber
Jul 25, 2015 01:34 PM
