MikeA
11-26-2003, 05:33 PM
NEVERMIND I GOT IT FIGURED OUT!
I have saved a picture to use as my aviator, but I can't use it since it is 350X350 pixels. Also it is a flash .gif image
How do I save it as a .gif without losing the flash image?
mikeb
11-26-2003, 05:42 PM
dude, you are smarter than that
Peggy
11-26-2003, 06:25 PM
you bumped a thread only 40 minutes later? you usually bump when it's a day or so later and no responses...you must spend all day on here =P
anyways, what are you talking about, MikeA...a Flash .gif image? is it Flash OR is it .gif? if it's Flash then i'm not sure you can use that for an avatar...if it's a .gif and you need to resize it, use something like Gif Animator...it'll take each frame by frame and you can resize it then
brothervoodoo
11-26-2003, 06:30 PM
Is it flash or a gif, or an animated gif like mine? First you have to shrink it down, I think the maximum here is 100x100 pixels and file size no greater than 6 or 10 KBytes.. No much to work on if you want to make an animation.
??? why is name showing up as Peggy???
MikeA
11-26-2003, 06:57 PM
Yes it is an animated image that is 350x350 pixels and 125 KB in size. How do I make it smaller?
brothervoodoo
11-26-2003, 07:40 PM
Originally posted by BRx8
??? why is name showing up as Peggy??? Ha ha.. peggy.. Don't fight the flow, just go with it.. :D :p
well it's weird...this Peggy person seems to hail from Bumblefcuk, MS and registered at the exact moment i posted...my question is, why Peggy and why Nowhere, MS?
ok fine, i'm now known as Peggy :D
Omicron
02-06-2004, 07:45 PM
??? why is name showing up as Peggy??? This happens when there's a confusion with the browser cookie on your system. To fix it, log out of the site, close your browser, and log back in.
