ecu compatable
Old Aug 16, 2008 | 07:36 PM
Rotore_787's Avatar
I kill Vtec's
ecu compatable
curiousity killed me but sorry since this not what you guy are talking about but can i use a rew with a renesis ecu???
Sorry if its a stupid question i just thought of it here at work and im clueless.
Thanks,
Naldy
Old Aug 16, 2008 | 07:45 PM
expo1's Avatar
He's as bad as Can
The rew ECU would not work on a renesis. What is your goal, maybe there is a another option.
Old Aug 16, 2008 | 07:50 PM
shaunv74's Avatar
Power!!
I think the question was the opposite. Put a renny ECU on a 13b-REW correct?
I suppose with a ton of work to spoof all the stuff you don't have. It seems like a stand alone Bosch or MoTec would give you better results for cheaper/less work. The Renny ECU is plugged in to everything from the AC to the traction control. I would think you'd have to spoof all that just to get it to idle.
What do you hope to gain from the Renny ECU? the multi maps by gear and decel?
Old Aug 16, 2008 | 08:37 PM
Rotore_787's Avatar
I kill Vtec's
i was just curious because when i get back on my feet i want to swap the renesis out for a lower compression rotary like a 12a, 13b-rew or a 20b so i can boost the hell outta it. (just want to get up to 475-500rwhp
Thanks,
Naldy
Old Aug 16, 2008 | 10:45 PM
Spoof the inputs to the stock ECU and run a standalone......
Microtechs and Haltechs work well on 13B's..there are lots of success with these.
Motec's great too...if you hve deep pockets
Old Aug 17, 2008 | 06:34 AM
Rotore_787's Avatar
I kill Vtec's
Spoof???
Old Aug 17, 2008 | 02:38 PM
Sorry....assumption made...
You need to give the stock ECU certain signals ( like trigger wheel signal, MAF , ECT, etc )so it thinks it is still in control so that Throttle, dash and TCS/ABS/DSC power steering etc still work correctly..
So what you are doing is keeping the ECU happy driving the auxiliary devices while the standalone runs the engine..
Old Aug 17, 2008 | 06:11 PM
shaunv74's Avatar
Power!!
hmm. Although it seems like he wants to drop a 13b-rew into the RX8 and try and run it with the stock ECU.
I suppose it's possible but haven't seen it done. The only swaps I've heard about are the 20B swaps. Scott at Mazsport would probably be your best bet to ask for advice on that.
It seems like you'd just have to figure out what the engine inputs are to the ECU and make sure you have something coming from the REW motor that's equivalent. I don't know much about the difference between the two. You could be the first of us to try it.
Old Aug 17, 2008 | 09:36 PM
Rotore_787's Avatar
I kill Vtec's
thank you guys i'll look into this
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
Draken
Sep 21, 2015 06:14 PM
neoksk
Sep 21, 2015 12:31 PM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
