cel p0031
Old Aug 14, 2008 | 07:18 PM
Mr.&Mrs.Magic's Avatar
cel p0031
I have an error code reading P0031 -front o2 sensor. While replacing the clutch I managed to pinch the wires running along the trans. One wire was cut in half the other appeared to never have been touched. my father fixed the wire with solider and I figured we were good but i guees not. can annyone tell me exactly which(color) wire would give me the cel. Also my access port will not read afr or stft. how big of a deal is it that the cel is there this is my only car and i have been without it for a mth so is it safe to drive?
Old Aug 14, 2008 | 07:35 PM
MazdaManiac's Avatar
Any of the 4 wires going to the front O2 sensor could cause that CEL.
How did you manage to get the harness in between the motor and the tranny?
Just pull the harness off of the tranny (all of the connectors and hold-downs), disconnect it from the sensors and pull it back through the engine compartment so that you can get a good look at it.
Driving your car that way wont "hurt" it, but why would you want to?
Many of the race teams remove both sensors completely. It just means you are running off of the native fuel maps all the time, which means you are probably quite rich under 4800 RPM all the time.
Old Aug 14, 2008 | 07:48 PM
rich does not begin to describe the funk I'm smelling with a full 3" catless system. trust me it's very easy to get in there we even taped it up so it would not happen but here i am
Old Aug 14, 2008 | 07:52 PM
Well, that is understandable.
Its shooting for 13:1 with no load and 12:1 everywhere else.
I wouldn't be surprised if your idle AFR is 12:1 or less.
RevMeHarder
Jun 1, 2026 02:30 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
