Adding OEM Moonroof
Old Aug 13, 2008 | 06:46 PM
KITTRX8's Avatar
Adding OEM Moonroof
Hello everyone. I just picked up a FACTORY moonroof assembly. It includes EVERYTHING, motors, wiring, module, glass, tracks, shade, switches.....everything. I wanted to add a moonroof to my car but choose not too based on reviews I have read and the curves of the RX8's roof VS the flatness of after-market moonroofs. My question is has anyone added an OEM moonroof to their car or heard of this being done. My plan is to take it to a moonroof install shop and have them do it. I figure the process is basically the same, only instead of popping in an after-market roof, they will install an OEM unit. Any info out there on this????
Old Aug 13, 2008 | 08:07 PM
kersh4w's Avatar
Hit & Run Magnet
i cant think of anyone that has done this. its been discussed a bit though. expect to pay a grand.
Old Aug 13, 2008 | 08:36 PM
MazdaManiac's Avatar
Don't for get to get the roof liner and, well, the roof.
The stamping for the upper is different between the GT and the base model.
Its gonna be a LOT more than $1k in labor and it will probably still suck.
Old Aug 13, 2008 | 08:51 PM
expo1's Avatar
He's as bad as Can
How involved would it be to go from Sunroof to fixed and regain the lost headroom? Could you leave the glass panel in place, remove any parts of the mechanism that are in the way, get a new headliner or have one made. I hardly ever open the thing all the way.
Old Aug 13, 2008 | 09:02 PM
KITTRX8's Avatar
I just realized, it won't work due to the fact that cars from the factory with a moonroof have rolled roof metal that works to create a seal for the roof. I could not achieve this after the fact, thus causing it not to seal properly. I already got a quote on labor and you are both off, it was $475 to install (from a known and very competent shop that only installs moonroofs). I bought the complete moonroof assembly for $50 from a friend. So, had the sealing been able to work, I could have done it all for $525.......oh well.
Old Aug 13, 2008 | 09:10 PM
expo1's Avatar
He's as bad as Can
How can you say "it could have been done for $525" and " I just realized, it won't work" in the same post?? Could you or couldn't you get a OEM like install without any leaks for $525??
Old Aug 13, 2008 | 10:38 PM
KITTRX8's Avatar
It COULD have been done, it just wasn't very feasible. You can do pretty much anything, wether the results are good is another story......
Old Aug 14, 2008 | 12:49 AM
kersh4w's Avatar
Hit & Run Magnet
thats like saying i could add a turbo (ebay) to my car for $500. all i need is a downpipe. and a reliable turbo. and a new kit. the piping is probably good though.
man though, that $500 turbo sure is feasible.
Old Aug 14, 2008 | 06:25 PM
KITTRX8's Avatar
Yeah, let's pick apart wording here because that's what's important. Way to get the point of the statement. For those who really needed things spelled out for them, maybe this will work:
I got a great price on the install, to bad the equipment won't work.
There, are we all satisfied with that one? No? Ok, lets try this one:
With a price quote like that, its too bad I can't take advantage of it.
Now that we have completely covered phrasing and quotation, maybe we can move on eh?
Old Aug 14, 2008 | 06:56 PM
paulmasoner's Avatar
Asshole for hire
hehehe.... they're just poking at you.... cause they already knew that you could get a sunroof put in for a few hundred bucks. but to get one put in that was OEM quality with no leaks etc would be easily a grand +
Old Aug 14, 2008 | 11:38 PM
Outkast187's Avatar
$500 seems about right, I have seen em done cheaper, and they are nice quality work. Its a 1 day job, $1K is way extreme.
Old Aug 15, 2008 | 09:38 AM
PBlue's Avatar
Dial P for Phantom
What about going the other way?
Should i ever decide that autox is more important than having a sweet hair tan, Anyone ever consider chopping off their moonroof and putting on a ...... roof-roof?
Old Aug 15, 2008 | 10:05 AM
KITTRX8's Avatar
I would have no problems going with an aftermarket moonroof......but I have heard a lot of horror stories about them in the RX8 (due to the curves of the 8's roof).
Old Aug 15, 2008 | 12:33 PM
I don't think I've seen anyone add an OEM Moonroof to an 8. What are you going to do now Kitt?
Old Aug 15, 2008 | 07:39 PM
Rote8's Avatar
My understanding is the entire top (including the moon roof) between the two side roof seams can be replaced by a competent body shop.
Look on the top of your car, you should see two seams running front to back about 6 to 8 inches in from the sides of the car.
You need everything in between those two seams, both inside and out.
Good luck, you will most definitely need lots of luck and a very skilled body shop.
Old Aug 15, 2008 | 09:23 PM
KITTRX8's Avatar
I've personally laid hands (and eyes) on four 8s with an added non-oem power moonroof and they all turned out just fine and have been on the cars for years. I may just go ahead and try that route!
Old Aug 15, 2008 | 09:26 PM
Asshole for hire
go do that and report back in 2 years
Old Aug 15, 2008 | 09:41 PM
chrism's Avatar
Misfit Moderator TnC
put a moonroof on an 8 that didnt come with it and your car is structurally unsafe...that is where most of the meat comes from with the lack of pillars between the doors...the ones with moon roofs already have a stronger and different roo than those without.....dont be stupid.....search more this has been discussed multiple times even with one person returning a car because the roof was aftermarket and unsafe
Old Aug 16, 2008 | 12:12 PM
KITTRX8's Avatar
True, but most people (if not all) who had issues with it, had so because their interior structure was cut due to having a moonroof installed that slid back inside the roof while open. The person who returned the car had this type of roof installed. I would install the type that goes over the roof (like OEM) while open. That requires no cutting or damaging of the interior bracing / structure.
Old Aug 16, 2008 | 12:26 PM
Asshole for hire
ok let me make it simple.... the roof with and without OEM sunroof has different structural design.... you CANT just cut a hole in the roof and add an OEM sunroof. You're either going to lose structure, or your gonna have to re fabricate it the way it is on the sunroof models.....
like we've been saying, there is no proper and safe way to do it at a reasonable cost level(less than a grand'ish)
Old Aug 16, 2008 | 03:23 PM
kersh4w's Avatar
Hit & Run Magnet
i want to get rid of my moonroof.
Old Aug 20, 2008 | 08:21 PM
secret8gent's Avatar
the enemy in the mirror
don't forget the drainage system too (runs down a front and rear pillar)
Old Jan 22, 2010 | 10:42 PM
longpath's Avatar
I, too, am interested in the feasibility of deleting the OEM moonroof. Since my 2004 was bought in the US, not in Canada, I had to get the moonroof to get the other features I wanted, and I would much prefer the extra headroom. I'm still searching to see if there's a dedicated discussion on the subject; but this topic came up during the process of that search, so I thought I'd put a feeler out, all the same.
92trbolzr
May 18, 2025 09:04 AM
mdl0209
May 23, 2019 05:46 PM
Quiggs321
Sep 30, 2015 05:34 PM
