CEL blinking
Old Aug 13, 2008 | 01:44 PM
Zeal's Avatar
Totally Rotarded
CEL blinking
Anybody know why my CEL would start to blink when I'm at high speeds at high rpms? When I drop down to like 80-95 it stops blinking. This happens when I go around 115-130.
I'm running royal purple 5w20 and I have an exedy stage 1 clutch and same lightweight flywheel as the daytona rx8. I also use Protek fuel modifier (don't think this matter but throwing that in there)
I was thinking this light is for the engine running rich, but it'd be great if anybody knew for sure.
Old Aug 13, 2008 | 01:49 PM
lilring's Avatar
Finally a MT
most likely its just a misfire. check your plug wires and make sure they are tight. you might need new wires or you can do the ghetto fix.. ( take of the loose wire and tight the metal clip in side) if thats not it. next check the spark plugs
Old Aug 13, 2008 | 01:59 PM
Zeal's Avatar
Totally Rotarded
Thanks for the response, I guess I'll just upgrade to better wires and prolly should get new plugs, I'm at 32k miles and I drive rather spiritedly.
Old Aug 13, 2008 | 03:00 PM
lilring's Avatar
Finally a MT
yes that will probley be your best bet. i am doing the same thing once i get some more money. i heard RB wires are pretty good. but im not sure about what spark plugs and the best
Old Aug 13, 2008 | 03:03 PM
quazmosis's Avatar
Chode
^ sparkplugs.com
Old Aug 13, 2008 | 03:22 PM
Feras's Avatar
the Doctor
sounds like a misfire! do it a few more times and it will get solid...regardless you should be able to pick up the code on a reader.
Old Aug 13, 2008 | 05:46 PM
racing beat has some nice wires. OEM plugs work the best on N/A cars so make sure you don't change them to some crazy bosch plugs. (no matter what the guy at the auto parts store says)
Old Aug 14, 2008 | 02:44 AM
i am going to break this down for you.
flashing cel is a miss fire...
when you drop it down you are not a full throttle are you?
common reasons for a missfire.
bad plugs
bad plug wires or one or more loose.
bad coils
fuel pump
running a high rpm test with less than .25 tank of gas.
your flywheel and clutch dont matter.
proteck and premix are the same thing, search for that..
it is not running rich.
get the codes.
Old Aug 14, 2008 | 03:14 AM
Zeal's Avatar
Totally Rotarded
thanks guys. i think i'll go with RB wires and stock plugs since i'm N/A.
about the coils: i heard of an upgrade to the coils that's much better than the stock ones, anybody have info on this?
Old Aug 14, 2008 | 03:34 AM
Jon316G's Avatar
Grasshopper
BHR's Ignition System Offerings
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/bhrs-ignition-system-offerings-145128/
Mazsport Ignition Solution!
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/mazsport-ignition-solution-134081/
Plenty of info...
Old Aug 14, 2008 | 03:45 AM
the upgrade to the coils is mazda has changed the design.
if you are interested, i have a set of the last design coils and a set of racing beat wires for sale..
send me a pm.
Old Aug 19, 2008 | 03:46 PM
ssspeedfreak's Avatar
I have the same issue so I will do the same thing. I'm always looking for any reason to upgrade my stuff! This CEL light is annoying because I can't pass the inspection or Register my car.... I thought it was a bad Cat... Let me know how yours goes Zeal and I will do the same.
Old Dec 21, 2008 | 06:54 AM
Nemesis GP's Avatar
Hi gents South African user here, having the same issue with my car-the engine was just overhauled-new seals springs etc. been to mazda and they give me error code P0130 coming up tells me I need a new front O2 sensor-will a bad O2 sensor cause the engine light to flash? it only flashes above 4000rpm...???
Any advice will be greatly appreciated
Old Dec 21, 2008 | 08:00 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
See your other thread!
Old Dec 21, 2008 | 10:01 AM
I8U's Avatar
I8U
A little surprised no one has asked this yet...but where in the nation is a posted speed limit of 115, let alone 80? Hmmmmm...
Old Dec 21, 2008 | 10:06 AM
Mazurfer's Avatar
I assumed he was on the track.................yeah.............that's it.......on the track!
Old Dec 21, 2008 | 10:09 AM
I8U's Avatar
I8U
Haha! Granted he posted this back in August so it really doesn't matter now. hehe
RevMeHarder
Jun 1, 2026 02:30 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
