West RX-8 Forum Serving CA, NV, AZ, HI
CEL still on
Old Aug 11, 2008 | 12:17 AM
Mayersteve's Avatar
Exclamation CEL still on
My light is still on after installing a RB cat back and a agency power pulley I know this shouldnt matter. Also I just found my insulation breaking down on my Mazdatrix wire set, I put insulation on and that fixed the rough idle until I get new ones. Does anyone know if the RX8 is OBD II compliant and if not what will work, or does mazda have to reset the the light, and will the light reset itself.
Steve.
Old Aug 11, 2008 | 03:06 AM
tiltmode43's Avatar
OMGITM!
Yes obdII
If you don't have a code reader you can stop at someplace like pepboys, they'll usually read it for free
Old Aug 11, 2008 | 04:10 AM
Flashwing's Avatar
3-wheeler
Steve.
Steve,
If you installed the AP pulley, you might have triggered a CEL cause of a misfire. You need to reset the e-shaft position sensor after installing the pulley to ensure the ECU has the correct position settings.
To do so, turn your ignition to ON (which the full dashlights) and press your brake pedal approx 21 times. You should see your oil pressure gauge go to halfway and then fall to zero. You can then start the car.
Otherwise I'd get the CEL code pulled to see what it is. Either way, if you didn't complete the reset after the pulley install it needs to be done anyway.
Old Aug 12, 2008 | 12:16 PM
Mayersteve's Avatar
Thanks guys i'll try that
RevMeHarder
Jun 1, 2026 02:30 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
