View Full Version : Mazsport Type 1: some questions
tajabaho1
08-07-2008, 05:36 PM
Hey guys, since I am a total nub at turbo thinging....... well, in a tuning sense anyways
I was wondering if there are anything wrong with these graphs
I went on a logging run yesterday night
btw, I have done other log runs before, in 3rd gear for example, the car boosts up to 7PSI, mostly it'll be around 6 PSI
in 2nd gear (the one I did the run in) however, it spooled to only 4 PSI, and it's not constant boost, it looks like im losing manifold pressure, it goes from 4 to 2 to 3 to 4 etc etc
here's the graphs
http://i37.tinypic.com/2yyrqkn.jpg
http://i35.tinypic.com/xlgqkl.jpg
tajabaho1
08-07-2008, 06:07 PM
also, the first few days that I got the turbo, it spooled to 7 PSI, always, always, but now no matter what gear, it only goes to 4 PSI, I have no clue why,
Psychofox
08-07-2008, 07:11 PM
there's a leak somehwere
636
08-07-2008, 07:51 PM
Yeah i think you got a leak too.
paulmasoner
i think he just Taja'd the install :)
we ruv you taj!
tajabaho1
08-07-2008, 08:23 PM
there is a leak in the manifold? but how? I haven't done anything T.T
paulmasoner
08-07-2008, 08:25 PM
they said a leak somewhere... maybe it is the mani, maybe not... have you gone back tio check every single nut and olt and fitting since installing?
thats a very important step
mysql
08-07-2008, 08:26 PM
That's the classic symptom of installing the turbo backwards.
Psychofox
do you use a boost controller?
where do you tap your boost/vacuum signal?
rotarenvy
08-07-2008, 08:28 PM
I've heard you should re-tighten all hose clamps after the first few drive cycles as the hoses shrink and change shape with heat and pressure.
maxxdamigz
08-07-2008, 10:12 PM
My Greddy BOV which is the default Mazsport BOV leaked after install. We had to tighten it all the way down and then back it off some. It sounds like you are running with no EBC as I think the Mazsport kit ships with a 7 psi spring.
tajabaho1
08-07-2008, 10:15 PM
ok, I retighted every single charge tube, and every single clamps
everything, I haven't tried the car yet, but should have no more leaks
I dont have a boost controller, I run a vaccum hose from the turbo to the wastegate, but that one is bent, it might have a leak in that tube, but i cant get to it since I don't have a jack (mine broke)
hopefully it's that and that it's minor, :D
maxxdamigz
08-07-2008, 10:26 PM
well, if your signal to the WG is borked, underboosting might not be the symptom you'd see.....
tajabaho1
08-08-2008, 12:26 AM
yea, I'd think that it would simply not spool at all is what I'm thinking
qtwre
08-08-2008, 02:59 PM
If your wastegate wasn't getting a proper representation of the pressure being pushed by the turbo, it wouldn't open and you'd get too much boost.
When it doesn't see any pressure it's closed (to build boost), and it opens as pressure increases.
tajabaho1
08-08-2008, 03:07 PM
I see, so there probably is a leak.........but where??!!
rotary.enthusiast
08-08-2008, 03:23 PM
Is the spring tension on the WG adjustable?
chickenwafer
08-08-2008, 03:31 PM
Fix your wastegate line now, before you drive anywhere. That's how motors go pop.
Did you try adjusting your blow-off valve? Double check to make sure no vacuum nipples are open.
tajabaho1
08-08-2008, 03:47 PM
ok, I just came back from fixing the wastegate actuater vacuum line, I put a brand new line in and routed it differently + heatshielded it a bit more
I haven't messed with the BOV, mine is the HKS SSQV and it seems to be fine
I will re-tighten the boost gauge once I finish lunch just to make sure, cus that is the last thing I installed
636
08-08-2008, 11:24 PM
Rofl , installing the turbo backwards.... Hope you didnt weld the compressor housing onto the downpipe :)
tajabaho1
08-09-2008, 12:44 AM
you cant posssibly put it on backwards
you'll have to be epic Taj to do that
RK
08-09-2008, 12:54 AM
Nah. That would just be a regular Taj. A regular Taj IS epic. ;)
whoneedspistons
08-09-2008, 01:00 AM
so how did it turn out after you tightened everything...
chickenwafer
08-09-2008, 01:30 AM
Do you hear any noises when under boost like air rushing (like a tire deflating rapidly)? Drive with the windows and try to hear it, it should be loud if you have a serious leak.
Also check your intercooler, I've seen phantom boost leaks from bad welds on an intercooler.
tajabaho1
08-09-2008, 03:42 AM
ok, I tightened everything
turns out my manual boost gauge
is
epically
Tajed
like
seriously
Tajed
like, leaking
monstrously
not the vacuum line that it connects to
but the boost gauge it's self
god damn 20$ knock off ebay gauge!
I didn't buy it my self, someone bought it for me, sucksballz,glowshift should getsued
i used the int-X to log it again today
7 PSI like normal yo!
paulmasoner
08-09-2008, 03:43 AM
^^ why what happened??? did YOU touch it or something??
hehehe
good to hear, now get coils
alz0rz
08-09-2008, 03:48 AM
lol, good thing i didn't get that glowshift gauge from the fs forum!
tajabaho1
08-09-2008, 06:07 PM
ok well, I uninstalled it, the boost now goes up to 7......but it still varies insanely
so my guess is that I fucked the wastegate, or my coils......or something
mysql
08-09-2008, 06:09 PM
what is the boost source? use the vfad nipple.
tajabaho1
08-09-2008, 06:10 PM
I am using the Vfad nipple
dannobre
08-09-2008, 08:50 PM
It's unlikely that you fu*Ked the wastegate :) It's quite difficult even for you :lol:
You need to get a Boost gauge, and a WBo2 .....
tajabaho1
08-09-2008, 09:24 PM
I use my laptop as a boost gauge
chickenwafer
08-09-2008, 11:12 PM
You still need a wideband O2 sensor, Taj, and some tuning. My guess is you're running the base map right now, which is really conservative and can still potentially do harm to your motor. I would stay out of boost until you get some professional tuning and a WB02
mysql
08-09-2008, 11:14 PM
I use my desktop as a window to the world.
tajabaho1
08-09-2008, 11:52 PM
I understand, I will try to stay out of boost
not that there is any left..........like seriously, there isn't any leak, and still, the turbo just doesn't spool up no more
sigh, that vaccuum line failed, I'll need to jack up the car tomorrow again and replace that vaccuum line
my motor is fine for now (compression good) the coils are ok, the sparkplugs aren't so good
I'm using the FD plugs that Scott sells on his website (as a matter of fact, I bought it from him) and one, if not two of them, are busted, since I can hear the leadings going fine (the first spark) but the second one I can hear a *tack* tack* *tack*
now, with a blown rotor, I figured the sould would be very wierd, but I never heard one before on an rx8
if it's anything like my old FD, it wouldn't whine anymore, but would be a highly disturbing clank at idle
those of you who had blown motor please tell me, in some type of word, how it sounds like
chickenwafer
08-10-2008, 12:01 AM
Blown motors have all varying degrees of weird sounds. When mine blew, it just felt sluggish and didn't make any abnormal sounds.
Other times you can hear odd metallic sounds, like scraping. The most common is poor idle vacuum (under 16 inches without the A/C on or any load) and a sound similar to a big tractor, sometimes lots of vibration through the shifter.
tajabaho1
08-10-2008, 12:24 AM
no vibration, -19mm HG idle, -17 sometimes
swoope
08-10-2008, 12:39 AM
taja.
mr wafer has a hymee scan tool for sale.. you might invest in it!!
beers :beer:
swoope
08-10-2008, 12:41 AM
well,
that means you likely dont have a blown motor..
but that does not mean you dont have a leak.. think for a second, you might have a connection that fails under boost??
beers :beer:
tajabaho1
08-10-2008, 03:40 AM
tmr I will go get a jack (my stock jack got owned when my friend with an sr20 backed up over it)
and I will most likely replace the wastegate actuater vacuum line, because it is bent, and this is most likely causing it....same symptom as my friend's SR 20
I will also look into the charge tube that connects the turbo to the intercooler, cus that might have been knocked by the wheen hub
