sup guys, new to the site
Old Aug 4, 2008 | 09:23 PM
vglnte1's Avatar
i just got a black 2005 RX-8 and came here to get the scoop on stuff. Its pretty much a daily driver. i also have a 2002 corvette with a 416 LS3 as well.
My first question is.......the oil light has come on...how low is the oil at that point? how much should I put in? I know when it comes on in the vette its about 1 quart low...answers?
Old Aug 4, 2008 | 09:26 PM
Spinning Sushi's Avatar
I <3 Sushi
It means you're dangerously low. Go check your dipstick and then follow this chart:
Originally Posted by Nubo
[|--------------------] 1.8 quarts low
[-|-------------------] 1.6 quarts low
[-----|---------------] 1 quart low
[------------|--------] 1/2 quart low
Old Aug 4, 2008 | 09:28 PM
I <3 Sushi
Also, you should always check your oil level at every gas fill-up, it's a good common practice for any car, especially the 8.
Old Aug 4, 2008 | 09:30 PM
I <3 Sushi
One more thing, the RX-8 consumes oil. You'll be down about a quart of oil approximately every 3,000 miles. The light should go on by then, this is the reason why to always check on your oil level for the 8. I usually top it off every 1,000 miles and change the oil at every 3,000 miles.
Old Aug 4, 2008 | 09:36 PM
vglnte1's Avatar
how many quarts go in? and what oil weight does the dealer use? 5w-20?
I just want to add the same stuff until I change it to what i want
Old Aug 4, 2008 | 09:38 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah it's low you need to check it every other oil change! welcome to the addiction
Old Aug 4, 2008 | 09:39 PM
04RX8man's Avatar
the dealer would have put in 5w20 but depending on your location you should use 5w30 or 10w30
Old Aug 4, 2008 | 09:40 PM
vglnte1's Avatar
im in Illinois where we have humid hot as hell summers and cold as **** dry winters
Old Aug 4, 2008 | 09:46 PM
TopGear8's Avatar
mkuhnracing.com
Welcome to the club man, Lets see some pics of the 8 and the vette!
Black is the best color btw..
Old Aug 4, 2008 | 09:47 PM
I <3 Sushi
Geez... I just told you how much oil you need...
Mazda recommends 5w-20 non-synthetic oil.
Old Aug 4, 2008 | 10:15 PM
tajabaho1's Avatar
Destroying Threads
your retarded pls sell ur car
Old Aug 4, 2008 | 10:33 PM
04RX8man's Avatar
illinois i would use 5w30 in the summer and 5w20 in the winter (if your gonna drive it in the winter personally i would not i know how shitty it gets in the snow) so buy a beater....but if you do drive it 5w20 will help the warm up time
Old Aug 4, 2008 | 10:41 PM
vglnte1's Avatar
i meant total amount of quarts...i havent looked in the book or even lifted to hood yet. ive been to busy building the vette.
Old Aug 4, 2008 | 10:43 PM
vglnte1's Avatar
no pics of the 8 yet. but here is the vette
Old Aug 4, 2008 | 10:46 PM
I <3 Sushi
Here you go:
Originally Posted by swoope
here is how you do it....
after removing the oil filter
1 jack up the exhaust manifold side of the motor (pass side in usa)
2 take out drain plug, let drain till just a trickle comes out.
3 let down the car, jack up the other side.
4 let drain till complete..
5 install drain plug. drop car back to ground.
6 install oil filter.
put 5 qts of oil in car. start car let run for a bit... but dont flood it...
check oil level..... fill as necessary...
i put in over 6 qts when i made this fortunate error...
hope this helps.
normally if you do the car flat, you put in ~ 4 qts...
if you do it this way you get out ~ 6 qts... as i said this happened by accident. i put 4 in ran the car and the dipstick was dry....
this is why i suggest 5 qts.... dry dipstick bad....
If you need more information on oil capacity, go here: https://www.rx8club.com/series-i-do-yourself-forum-73/diy-max-oil-out-oil-change-90879/
Old Aug 4, 2008 | 10:59 PM
vglnte1's Avatar
Here you go:
If you need more information on oil capacity, go here: https://www.rx8club.com/showthread.php?t=90879
cool, thanks for your help
Old Aug 5, 2008 | 12:59 AM
YaXMaNGTO's Avatar
It's a Cavalier
Nice car. LS3 stroker is a nice setup... what is it putting down, 490-520 rwhp? I also see the Nitto drags on the back. Getting them to hook?
Old Aug 5, 2008 | 04:15 AM
I <3 Sushi
No problem. Glad to be of help.
Old Aug 5, 2008 | 08:31 AM
jdoo's Avatar
Renesis SE3P wins this thread. Thanks for the ascii dipstick chart man!
Old Aug 5, 2008 | 10:48 AM
dozer's Avatar
on his 3rd rx8
hmmmmmm215 in the morning.....johns a tweeker...
Old Aug 5, 2008 | 11:11 AM
04RX8man's Avatar
nice lookin vette
Old Aug 5, 2008 | 11:26 AM
JRichter's Avatar
Void Where Prohibited
Congrats on the 8 and welcome to the club. Nice vette.
Old Aug 5, 2008 | 12:33 PM
SideOfBacon's Avatar
Old Aug 5, 2008 | 12:34 PM
lol, ascii art dipstick readings...
Old Aug 5, 2008 | 01:45 PM
tdiddy's Avatar
Finally Boosted!!!!!!!
Hi Carter! I was wondering if you would make your way over here sometime. Let me know if you have any other questions.
Guys - Vglnte has one very bad *** Vette but he is new to the rotary.
