First Mod Check Engine Light
Old Aug 2, 2008 | 09:11 PM
obx8's Avatar
I put in a K&N Filter today and got a check engine light. Is this normal? Should I pull the battery off for a second or something. The car does sound really cool with the new filter though. I hate that check engine light. I also removed the walls in the intake box.
Old Aug 2, 2008 | 09:30 PM
invasion08's Avatar
You should not get a check engine light from the k&n drop in air filter. Look under the hood and see it any hoses near the throttle bottle is off. Did you get gas recently? if so check the gas cap. If all the hoses are on then disconnect the battery and see if it comes back on or not. Also when you start your car after disconnecting thr battery your traction control lights will be on. it will go away the ecu just needs to re learn
Old Aug 2, 2008 | 09:41 PM
deadphoenix52's Avatar
meh.
did you by chance disconnect the MAF. idk why you would but that'd be something to check
Old Aug 5, 2008 | 08:41 AM
Outkast187's Avatar
ya, something got unplugged, or vacuum hose came off, something along those lines are likely.
Old Aug 5, 2008 | 09:24 AM
maxxdamigz's Avatar
Baro Rex
If it persists and the car is driveable, limp it to an Autozone or the like. They will pull the code for free.
Old Aug 5, 2008 | 10:19 AM
laythor's Avatar
I zoom therefore I am.
I'd agree with the gas cap idea.
vapor2
Nov 3, 2020 03:38 PM
arjunmshah
Aug 6, 2015 10:56 AM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
