Problem with rpm's, power and stalling
Old Jul 31, 2008 | 02:50 AM
ramzesgd's Avatar
Hi,
so I got problem. Let me describe it. Car was standing 3 months without driving, basicly it had one drive, but during this was flodded. It was standing 1,5 months flodded. Finally I had chance to start it - it works. But... from this moment car got problem with stalling. Every time when its warmed up it just not holding rpm's on neutral. Acceleration is also diffrent - from 1st gear the felling is like starting from 3rd. After that is ok, until 4000rpm - then is some kind of parachute, and again after is ok, until 6000 - again parachute. Basicly it doesnt have so much power like before.
Ive read couple of topics here and I was thinking about ignition coils - Ive change them and problem is still exists - just the throttle felling is better, but car is still shutting down after warming up and it doesnt want to hold rpm's. Rpm are jumping when car is cold.
Plugs ? Wires ? Fuel pump ?
Help me
Old Jul 31, 2008 | 07:26 AM
did You pull ur battery ?
if u did, thats what happen. let it re-learn.
Old Jul 31, 2008 | 10:01 AM
04RX8man's Avatar
Rotary Powered Countryboy
yeah NYC is correct about the battery if not I'm not completely sure no smoke? and run perfect till it gets warm?
Old Jul 31, 2008 | 10:19 AM
ramzesgd's Avatar
Yes, I pull out battery when I was changing coils. After that that but before starting engine, Ive pressed brake 20times to reset computer once again... is still stalling on low rpms
Old Jul 31, 2008 | 11:06 AM
04RX8man's Avatar
it possibly could still be relearning but possibly an engine problem? bad gas possibly? did you put any fuel stabilizer in it or are you running cheap gas?
Old Jul 31, 2008 | 11:39 AM
It takes about 3-5 drive cycle to complete the re-learn cycle.
So just live with it for a while, it will idle back to normal after that(unless u have serious engine problem)
Old Jul 31, 2008 | 11:53 AM
Socket7's Avatar
ಠ_ಠ
The computer relearning curves should not cause stalls at idle. If you have not changed the plugs and wires since it was flooded, this would be my first course of action. after being left flooded for a month and a half I'd be shocked if the plugs weren't completely fouled
Old Jul 31, 2008 | 12:04 PM
it will cause it to stall, most modern cars are like that, manual transmission cars.
its not like cause stalls at idle, its not even holding @ idle. rpm just drops. since the computer doesnt know the right amount of throttle yet.
Old Jul 31, 2008 | 04:49 PM
Socket7's Avatar
ಠ_ಠ
I have reset my ECU by the 20 brake pump method, and the battery disconnect method. Many times. My car has never stalled because of it.
Any modern car it should never stall, unless because of driver error or mechanical failure.
Old Jul 31, 2008 | 10:51 PM
when I asked the guy at a garage, he said most modern car would stall if u pull the battery. ECU re-learning. nothing to worry about.
The service manual didnt say anything about stalling, but it did say something about re-learning. so...
whatevaz, idle works after a while. no big deal.
Old Aug 1, 2008 | 02:38 AM
ramzesgd's Avatar
Guys I dun think ECU is learning. I pull out battery cabel many times - and this issue got nothing to do with this.
Car is stalling, rpms are not stabil, there is lost of power. 40K miles on the clock.
Old Aug 1, 2008 | 10:51 AM
Socket7's Avatar
ಠ_ಠ
Change your spark plugs and plug wires. Plugs will foul if the engine is left flooded. I'd say check the cat as well, but that would only cause problems at high RPMs; Also, you are running without one.
Old Aug 1, 2008 | 01:27 PM
puch96's Avatar
It could also be a TPS problem... (throttle position sensor)
Old Aug 2, 2008 | 04:11 AM
ramzesgd's Avatar
New info: i notice that from stalling problem I can smell petrol in the air, before it was just smog. Anyone know smthg?
Old Aug 3, 2008 | 10:58 AM
Socket7's Avatar
ಠ_ಠ
How can I know anything if you don't respond to previous answers?
Have you changed the plugs yet?
Old Aug 3, 2008 | 11:10 AM
invasion08's Avatar
Pushing the brake 20 times does not reset the ecu it resets the e-shaft
Old Aug 4, 2008 | 09:51 AM
Charles R. Hill's Avatar
Owner of BHR
Make sure you reconnected your MAF sensor.
Old Aug 4, 2008 | 12:42 PM
hakuna matata!
Vacuum leak?
Old Aug 4, 2008 | 04:02 PM
Owner of BHR
Good point, alz. If it is, it would probably be from the VFAD vacuum supply hose being disconnected after the coil swap(IIRC).
Old Aug 4, 2008 | 04:49 PM
Deathcraft's Avatar
I pulled the battery out a few times in the past to clean...it never really caused stalling or rpm fluctuation.....
Old Aug 4, 2008 | 06:14 PM
ramzesgd's Avatar
No I didnt change those plugs, they r still the same from the flooding. The only thing i've changed are the coils. I dont have cat. Just a resonated pipe.
Old Aug 4, 2008 | 06:18 PM
ramzesgd's Avatar
What you mean? Tell more... my MAF sensor is clean.
Old Aug 8, 2008 | 01:51 AM
ramzesgd's Avatar
I went to Mazda service, they read out codes and they still dont know what can it be . They are suggesting that it can be o2 sensor, after flooding, when I started car I probably melt it. Can this be truth? Car doesnt want to pass 4000rpm. The only happy nesws is that its not a engine
Old Aug 12, 2008 | 03:22 AM
ramzesgd's Avatar
Computer is showing now that the mixture is not rich enough? Could it be new intake? Maybe is giving to much air compare to poor level of fuel?
Anyone got some ideas ?
Guys, I know there is someone that know something... ? Maybe burned o2 sensor?
Old Aug 12, 2008 | 08:28 AM
Owner of BHR
Damaged catalytic converter?
