RX8 Engine Light
Old Jul 28, 2008 | 04:02 PM
Mayersteve's Avatar
Exclamation RX8 Engine Light
I just installed a Racing Beat catback and power pulley and now my engine light is on, Has anyone else had this problem or heard of it. I did fire up the engine without the mufflers installed just to hear it, dont know if that did anything plus the crank trigger plate came off with the old pulley but I installed everything correctly and the car runs great.
Steve.
Old Jul 28, 2008 | 04:46 PM
welcome mayersteve!
the CEL should not have come on with those mods but starting it without the mufflers on most likely triggered the emissions light.
You can either disconnect the battery for about 20 minutes to clear the code or go to your local AutoZone and borrow a code reader. It might be able to read the diagnostic code (depending on the reader)
shouldn't be an issue though.
Old Jul 28, 2008 | 05:38 PM
Mayersteve's Avatar
I didnt think it would but I hate that light.
Steve.
Old Jul 28, 2008 | 06:57 PM
04RX8man's Avatar
Rotary Powered Countryboy
haha yeah go to autozone and get the code read DO NOT go to the dealer for this they will most likely charge u like 100 dollars to hook it up auto zone is free
Old Sep 22, 2008 | 09:10 PM
simplyphp's Avatar
durr durr durrrrr, your exhaust pwned your gauge cluster, hope it was worth it hahahaha... ha.
Old Sep 22, 2008 | 09:24 PM
StealthTL's Avatar
Metatron
Do the brake pedal dance to reset the NVM
S
Old Sep 22, 2008 | 09:53 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yep, it was the pulley that did it, you have to reset it as Stealth said.
You need to clear your eccentric shaft sensor profile
Turn the car to on.......do not start it....pump the brake pedal about 20 times real quick while watching the oil guage....once it sweeps right and then back to the left.....turn off the car and next time you start it, you'll be good to go!
If it doesn't work, then repeat it again and pump the brake quicker.
Still no luck?, then Disconnect your battery and pull the "room" 15A fuse in the interior kick panel. Wait 5 minuets and then reconnect everything.
Old Sep 22, 2008 | 09:55 PM
simplyphp's Avatar
^^ Yeah what they said. . . . and the brake part is very important.
Old Sep 23, 2008 | 12:32 PM
Mayersteve's Avatar
You know I was just asking for help, I dont need your comments and by the way it was worth it! The exhaust has nothing to do with it, its the pulley throwing the code which i fixed.
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
AussieGray
Jul 16, 2015 03:58 AM
