Offset grinding the "E-Shaft" ?
Old Jul 25, 2008 | 09:19 PM
Rote8's Avatar
On piston engines, there is a way to increase the stroke by offset grinding the rod bearing journal of the crankshaft; has anyone tried it with the rotary E-Shaft?
I believe it should work for a small increase in stroke, and also it would add compression as well. Yes, we are talking small amounts, but maybe we could get up to a 1.4 liter?
It would need some type of adapter bearings for the smaller E-Shaft diameter.
Any thoughts?
Anyone say "impossible"?
Old Jul 25, 2008 | 09:21 PM
How would that work....it needs to stay in the correct position in relationship to the epichondroid shape of the rotor housing.......
Old Jul 25, 2008 | 09:56 PM
Rote8's Avatar
So, it would not work without milling the rotor enclosure?
Hmm, something to do with scarred rotor housings besides melting for scrap?
Old Jul 25, 2008 | 09:57 PM
won't work period........sorry
Old Jul 25, 2008 | 10:30 PM
you really need to see the inside of one to understand how much it cant work..
go to how stuff works. and find the rotary section..
it might help..
Old Jul 25, 2008 | 10:41 PM
Outkast187's Avatar
It would take a whole new housing to be efficient. The idea is good, but wont work without building a whole engine around it basically.
Old Jul 26, 2008 | 12:05 AM
What do you think the new 16X engine is.......
Old Jul 26, 2008 | 12:08 AM
*** not that simple.
btw, you win!
Old Jul 26, 2008 | 02:21 AM
What do I win? The oversimplification of the year award ???
Old Jul 26, 2008 | 08:06 AM
i think you win the anti slosh!
Old Jul 26, 2008 | 02:15 PM
Rote8's Avatar
Yes, I had forgotten the seals still ride the housing on the intake stroke.
Longer seals to make up for the greater stroke would break easier.
I suppose you could increase the stroke , but only a tiny amount.
Anyone have a guess how many thousandths extra stroke you could get away with?
Anything more, and you need new rotors and the internal gear design too....
Hmm, change stroke and design a new planetary gear and rotor?
Old Jul 26, 2008 | 02:21 PM
You really need to see a rotary apart...you basically have no room to do what you're thinking...it's not a piston engine ....I'm afraid you have to look in other areas like porting to change the way the engine behaves.....
Old Jul 26, 2008 | 02:32 PM
636's Avatar
636
Rice Police
Or get an Ls7 lol
Old Jul 27, 2008 | 03:46 AM
Rote8's Avatar
Yes, the seals on the intake side cannot leak any more than one of the other sides of the rotor during compression or exhaust.
Let's just hope the 1.6 is a bolt-in upgrade.....
And the boost toys we have fit.....
Old Jul 27, 2008 | 04:20 AM
paulmasoner's Avatar
Asshole for hire
wouldnt that be a wet dream.....
never happen though...
Old Jul 27, 2008 | 06:18 AM
PhillipM's Avatar
It'll fit with a big enough hammer.
theblinkof
Oct 4, 2023 05:24 PM
hufflepuff
May 30, 2016 10:45 AM
mitchrx8
Sep 13, 2015 08:05 AM
airlive
Sep 7, 2015 08:32 PM
