Tein stechs made my car crooked!
Old Jul 25, 2008 | 10:45 AM
jinh0's Avatar
As the title states, the springs I bought dropped the front end, but alot more than what I've seen on other 8's lowered in stechs. (which isn't the problem )
but what I've noticed is that the rear end did not drop at all and in fact looks like it raised a little. The car now stands crooked and leaning forward.
I read a thread last night about someone who had a similar problem with rb springs and all he had to do was loosen the A-arm bolt and let it settle for 30 minutes and then retighten them? would this also fix my problem? Thanks in advance! :D
Old Jul 25, 2008 | 10:53 AM
jinh0's Avatar
Here is the difference between the two...
Old Jul 25, 2008 | 11:14 AM
jiggawha1's Avatar
Tejas
wow the back does look pretty high there haha
Old Jul 25, 2008 | 11:47 AM
dillsrotary's Avatar
jersey fresh
preloading is only for the front, you cannot preload the rear. The s-techs naturally lower the front alot more than the rear, it maybe normal
Old Jul 25, 2008 | 11:52 AM
m3pkrobert's Avatar
wow! that looks stock do u have more pics of the whole car so we can see how it looks right now
Old Jul 25, 2008 | 01:11 PM
NgoRX8's Avatar
are you sure it's installed properly? assembly order, spring position, etc
Old Jul 25, 2008 | 01:32 PM
jinh0's Avatar
as you can see from the first pic, the front end is clearly lower while the rear looks stock or even higher
Old Jul 25, 2008 | 02:01 PM
whoa, something is NOT right with that install.
I'd get in there and double check to make sure the springs are sitting properly. That looks HIGHER then stock.
Old Jul 25, 2008 | 02:58 PM
C Ya L8r's Avatar
Looks like you got them in backwards. Try swapping front to rear.
Old Jul 25, 2008 | 03:12 PM
dozer's Avatar
on his 3rd rx8
WOW who installed those?
Old Jul 25, 2008 | 03:31 PM
I8U's Avatar
I8U
Ya know, I think you're right...they maybe installed backwards.
Old Jul 25, 2008 | 03:32 PM
jzief128's Avatar
What are the Detes?
+1 on the springs being backwards. I think that's your problem right there.
Old Jul 25, 2008 | 04:13 PM
jinh0's Avatar
i dont get it though, the front springs drop the car 1.4" and the rear .7"
I don't think having them on backwards would cause this to happen.
and my mechanic installed them for me... I called him today about this and he told me to bring it in and he'll see what he can do... :/
Old Jul 25, 2008 | 05:16 PM
rotary.enthusiast's Avatar
The Local Idiot
The drop is greater in the front relative to the stock ride height, but the front and rear springs are not the same length. Installing the fronts (which are longer) in the rear, and the rears in the front will do exactly what you see in your pictures
Old Jul 25, 2008 | 05:22 PM
Astral's Avatar
Purveyor of fine bass
the springs are probably backwards.
remember that front and rear suspensions put different "loads" on the spring (different length of things), so the same spring in the front will cause a different drop than the same spring in the rear.
the fronts have a stiffer spring rate than the rear, so if you put the softer rear springs in the front, it makes sense that the front is so low. and if you have the stiffer front springs in the rear, it makes sense that the rear is so damn high.
Raise up the car using a jack (use the scissor jack if you dont' have anything), remove a wheel and take a look at the spring (or maybe you can get behind the wheel from under the car w/o removing it). You should be able to see the letter "F" or letter "R" somewhere on the springs. Make sure letter "F" is in the front and "R" is in the rear.
Old Jul 25, 2008 | 05:28 PM
J8635621's Avatar
Pew Pew Pew
When I installed my springs I made a stupid mistake (rushing) putting the rear sway bar back and it caught on something causing the rear to sit like that. I ended up bending the endlink. Just a thought.
Old Jul 25, 2008 | 05:29 PM
Silver_Surfer's Avatar
I4NI
I preloaded my rear. I had to adjust a **** load of points but My car sits lower than the OP's at the front and rear!
Old Jul 26, 2008 | 07:14 AM
altspace's Avatar
Eccentric Shafting
...and Astral and I both installed Teins on our 8s as well as many other combinations.
Old Jul 27, 2008 | 10:13 PM
yep, backwards.
Old Apr 15, 2010 | 12:42 PM
rotaryPilot's Avatar
So what was the problem finally ??
Old Apr 15, 2010 | 01:06 PM
X Rx8's Avatar
fug em
Holy thread bump! Springs were probably put on wrong f/r
Old Apr 15, 2010 | 01:18 PM
Bullitt's Avatar
In the pipe five by five.
Holy thread bump is right, but now I wanna see the pix!
Old Apr 15, 2010 | 10:48 PM
Pico's Avatar
It's Complicated
Bump.....................
Old Apr 22, 2010 | 07:09 AM
8upbad's Avatar
Jared
This thread is an instant classic.
Old Apr 25, 2010 | 02:26 PM
HaydonGS's Avatar
Lurker
Ive seen this happen more than I care to remember haha
they are deff intalled backwards
