Simple Headlight Adjusting??
Old Jul 24, 2008 | 10:22 AM
Docj78's Avatar
Please don't torch me for starting this thread, as I have read through several others, and there seems to be several opinions on how to do this...
I had new HID's installed at the dealer under warranty, and they are aimed way low(maybe 2 car lengths worth of illumination).
I have read that I need to remove the fender skins to access the adjustment bolt, that the wheel should be removed, amongst many other methods.
I see that the housing is actually visible from the inside of the engine bay after simply popping the hood, and that the phillips screw driver "adjuster" is accesible as well. Can the up/down simply be adjusted from under the hood??
Also, could someone explain what the manual means when it talks about 1st tightening, then loosening so that the headlights don't continue to loosen on their own while driving???
Old Jul 24, 2008 | 06:43 PM
Outkast187's Avatar
Yea, should be able to adjust under hood, havent checked though...never seen a vehicle that didnt adjust like that though. Dont worry bout the tightening/loosening deal. Pop the hood and take a look, its all pretty basic common sense stuff. Wait till dark, then pull up so you have a wall 10+ft away so you can see how much you are adjusting...a little goes a long way.
Old Jul 24, 2008 | 07:12 PM
Nubo's Avatar
Lubricious
YES. That little toothed adjuster is what the phillips fits into.
Ok, so you have the shop manual. What I think they mean is:
Always end your adjustment with a "tighten" (clockwise) turn. If you need to make a "loosening" adjustment, overshoot a bit so you can end with a tighten.
Old Jul 25, 2008 | 09:34 AM
Docj78's Avatar
That is how I interpreted the instructions as well, but wanted to be sure that is what they meant.
Old Jul 25, 2008 | 10:20 AM
DrewMan's Avatar
Culpam Poena Premit Comes
i tried to adjust mine but it just clicks in place. am i missing something?
Old Jul 25, 2008 | 12:43 PM
Nubo's Avatar
Lubricious
You could be using too small of a screwdriver. It takes a fairly large phillips head to fully engage the teeth and not slip. Other than that, maybe it's already at the limit of adjustment. Does it turn the other way?
Old Aug 2, 2008 | 05:14 PM
tj7723's Avatar
thanks for posting every one, i just had new headlights put in under warranty and are way to low
Old Oct 12, 2008 | 10:04 AM
lopezian2004's Avatar
Master Shr3dd3r
Maybe that's why my HIDs look like crap right now... i don't see the philips head adjuster though.. in the picture is it right above the taped wires.. that tiny black circle? The exterior section didn't help much.. maybe the technies can help with my problem!!!!
EDIT: Here are the pics of what it looks like
With fogs
Without fogs
Old Oct 16, 2008 | 09:39 PM
Jbill21's Avatar
Don't think it should look like that. Mine are bad too. I plan on trying to fix it this weekend...GL
Old Oct 16, 2008 | 09:42 PM
Rote8's Avatar
I think these cars have a headlight leveling sensor near the rear axle.
Could it be the issue?
(work on the back to fix the front)
Old Oct 16, 2008 | 09:59 PM
Transam kid 01's Avatar
The anti-ricer
My headlight leveling sensor is shot. Is there a way to adjust my lights without the sensor?
Old Oct 18, 2008 | 07:51 PM
GaMEChld's Avatar
Registered Noob
wow, from those pics that were posted, those lights are completely out of alignment, definitely low.
Old Oct 18, 2008 | 08:44 PM
Master Shr3dd3r
Yeah the bulbs weren't seated properly. I wanted to make sure they were seated before I start adjusting anything with the adjuster.. 95% better now... i still think one of the bulbs is kinda messed up. i'll post updated pics later on
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Nov 24, 2015 01:00 AM
drlubell
Sep 26, 2015 11:58 PM
