What size rotor for AU RX8s (2004)
Old Jul 21, 2008 | 06:08 PM
LittleJohn's Avatar
Hi Guys...
Tried searching, but I guess my search prowess is a little outta whack atm cos I can't find squat.
Could someone please let me know what size rotors our stock 8s (2004) have?
I've found a few places online, but there's an option for w/ sports suspension or w/o sports suspension.
As far as I can see.. the w/ sports suspension is 320mm up front.
Also, are DBA 4000 series rotors any good? or is it worth the extra pennies with go with the 5000 series II, two piece.?
TIA.
Old Jul 21, 2008 | 07:42 PM
DrGonzo's Avatar
AFAIK all Aussie RX8s came with the sports suspension and the w/out sports suspension applies to overseas models.
Old Jul 21, 2008 | 09:14 PM
takahashi's Avatar
Front is 323, rear is 302
I will get something better than DBA .
Old Jul 21, 2008 | 09:38 PM
LittleJohn's Avatar
Thanks Taka... what would you recommend for rotor and pads? Street use only..
Cheers,
Old Jul 22, 2008 | 09:08 PM
takahashi's Avatar
street use then DBA is not bad. 400 is very nice, although I only have it on the back and it withstand the heat ok on the track.
I am very happy with project mu rotor and they are 328! Project Mu HC+ pads gives good initial bite and make you very happy in traffic but the down side is very noisy and very dusty.
Project Mu is still on special me thinks. If you want some I can give you the contact of our supplier
Other like Endless and Ferodo are good too. Endless have similar rotor and it is blue, Project mu is lime green and nothing I found is yellow
Old Jul 23, 2008 | 12:27 AM
Revolver's Avatar
Shootin' from the hip
Why the change LJ?
Originals worn/warped or just playing with mods?
Old Jul 23, 2008 | 06:31 PM
LittleJohn's Avatar
Originally Posted by Revolver
Why the change LJ?
yeah.. my fronts have been giving me grief for quite some time. I had the first set replaced under warranty because of shuddering. I took a while to sort out, but when the dealer decided to change everything at the same time they got it working.. ie all pads and rotors.
But for the past 12 months, the shuddering has slowly crept back, but this time my baby is out of warranty. I've also notice the front rotors look a little worn, more than what I think is normal. So rather than buying the oem rotors again, thought i might go with something better.. and because it isn't from Mazda, I'll prolly same some $$ too..
Old Jul 23, 2008 | 09:36 PM
takahashi's Avatar
DBA 4000 will give you significant saving....
They are the same as OEM if not better.
5000 is much better since it is 2 piece but so does the price. haha
Project Mu/Endless is highend stuff. Are you interested?
Old Jul 24, 2008 | 02:52 AM
LittleJohn's Avatar
Hi Taka...
Interested? yes... but I don't think I'm able to part with enough $$ to go down the "high end" route..
Thanks for your input tho.
rx8inator
Sep 1, 2015 07:18 PM
rx8inator
Aug 14, 2015 10:53 PM
Mr.Durden
Aug 12, 2015 02:21 PM
GK1707
Aug 3, 2015 10:23 PM
