View Full Version : A way to get dried wax off plastic?
sazebac
11-22-2003, 03:48 PM
When I waxed my car I got some wax on some parts of the black plastic (bottom of the rear window). Any suggestions on how I might get this off?
jkamen
11-22-2003, 06:12 PM
I did the same and carefully used some rubbing alcahol. It is the best I ffound through trial and error. Still not perfect though. Make sure you armor all the plastic after and be careful of the paint, good luck.
Efini 8
11-25-2003, 09:07 PM
use meguairs cleaning for the window seals and weather trim, it should work.
Magic8
11-26-2003, 09:26 AM
You could try washing with Dawn. Use an abrasive sponge. Be careful. Takes a little elbow grease.
Magic8
MrWigggles
11-26-2003, 09:35 AM
Rubbing alcohol won't hurt the paint but it can remove your wax depending on which type you used.
-Mr. Wigggles
Kap
11-26-2003, 01:24 PM
Here's a link to another similiar thread posted awhile back
http://www.rx8club.com/showthread.php?threadid=14824&highlight=toothbrush
Efini 8
11-27-2003, 02:29 AM
exactly what I said, Meguairs... they solve all car cleaning problems!
demonfire
12-01-2003, 01:52 PM
Try an eraser. Like on a pencil. Really.
Or peanut butter. Yes, really.
Alcohol will strip the wax of the nearby paint, and drips. An eraser and peanut butter (not used together) can be easily controlled.
