Look at these Pics of my Headlights!!!
Old Jul 16, 2008 | 09:12 PM
Boom3k's Avatar
From: Los Angeles California Crenshaw District Cuhz..
Angry Look at these Pics of my Headlights!!!
http://www.boomspeed.com/boom3k/2008/IMG00086.jpg
The passenger side headlight is fricking low! i went to the dealer and the service guy told me that it was going to adjust itself. But its been a week now. Any suggestions other than "Buy a new headlight."??
HockeyRX-8's Avatar
TNC
Uhhh...pics aren't working.
Old Jul 16, 2008 | 09:13 PM
Easy_E1's Avatar
Can't see the pic.
Try another dealer. That one sounds like a bunch of "tards.
Old Jul 16, 2008 | 09:15 PM
HockeyRX-8's Avatar
TNC
Damn....but yea, try another dealer.
snipaz2420's Avatar
the bukkake master!
pics are working for me. i'll try to find it but there is an instruction manual for adjusting the headlights. hold up
Old Jul 16, 2008 | 09:16 PM
TopGear8's Avatar
mkuhnracing.com
there is an auto leveling system. if thats broke i have one to replace... and i have a passenger headlight to replace if you need that as well. Looks like its just that auto leveler. if youve hit anything on the road it may have broken the adjuster arm that connects to the suspension.
Boom3k's Avatar
how do i change the size of them i juss need the code for this forum
Old Jul 16, 2008 | 09:23 PM
snipaz2420's Avatar
the bukkake master!
found it
File Type: pdf
Old Jul 16, 2008 | 09:24 PM
snipaz2420's Avatar
the bukkake master!
that link shows u how to adjust the headlights.
Old Jul 16, 2008 | 09:25 PM
Rotr8's Avatar
whines all the way home
looks like the autoleveler is outta wack,, but in general passenger side lights are usually higher(driverside being lower for oncomig traffic) so they are really outta level,, tell your dealer to check the autoleveler again...
Old Jul 16, 2008 | 09:44 PM
Boom3k's Avatar
Im juss going to try to do what snipaz2420 said. I mean the auto leveling light isnt coming on so it might juss be needing a quick adjustment. by the way! the dealership did replace my lamp back in May so that might be it too.
Old Jul 16, 2008 | 09:49 PM
Boom3k's Avatar
but how do i get the headlight out?!?!?
Old Jul 17, 2008 | 03:02 PM
Adino's Avatar
CrossFit Eternal
Originally Posted by snipaz2420
found it
Nice! I saved it just for future reference. Appreciate the post
Old Jul 17, 2008 | 11:24 PM
05rex8's Avatar
sold the 8... :(
Maybe when the dealer put the new bulb in, they put it in upsidedown. I've heard of that happening before and looks similar to what yours looks like. Just a thought.
--Jonathan
Old Jul 18, 2008 | 02:13 AM
Boom3k's Avatar
Rex is right, it looks upside down. is there a way i can take it out and put it in properly?? i really have no idea on how to get the headlight out by the way.
Old Jul 18, 2008 | 08:46 AM
fwo's Avatar
fwo
i thought the lights had a locating tab on them that keeps them from being installed incorrectly.
Old Jul 18, 2008 | 09:27 AM
mysql's Avatar
Doppelgänger
the headlights are adjusted using a simple screwdriver.
but before you do that, make sure the arm that connects the headlights to the suspension is not bent or messed up. That will throw it off too.
Old Jul 19, 2008 | 12:09 AM
05rex8's Avatar
sold the 8... :(
Crank the wheel all the way to the left and undo the plastic clips in the inner fender well. Push the plastic out of the way and you should see a plastic cover. Unscrew it and you wil see a metal plug that attaches to the bulb. I believe you have to twist it a bit and then pull. It should come right out. There will be 2 clips you have to pinch and push out of the way and then you can pull out the bulb...slowly! You may want to have a flashlight handy because it's dark in there and hard to see what you are doing.
This is true, however, it has been done before and the metal clips will hold it in place even if the bulb is upside down.
--Jonathan
Jst4fun
Apr 17, 2021 07:43 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
drlubell
Sep 26, 2015 11:58 PM
