what should i do???
Old Jul 16, 2008 | 06:36 PM
VS8's Avatar
VS8
4 Cylinder Rotary
Unhappy what should i do???
i was washing my car at one of those self car wash were u spray it down yourself...well for some reason i forgot i had a cold air intake and i accidently sprayed filter...now my car has a CEL...
Old Jul 16, 2008 | 06:44 PM
tajabaho1's Avatar
Destroying Threads
nice, get a new filter
Old Jul 16, 2008 | 06:52 PM
VS8's Avatar
VS8
4 Cylinder Rotary
i thought so...do you know the size of the aem filter for rx8
Old Jul 16, 2008 | 07:36 PM
nuke0907's Avatar
Never Blend In
unless you completely tore up the filter you should just be able to let it dry.
Old Jul 16, 2008 | 07:40 PM
05rex8's Avatar
sold the 8... :(
You probably sucked in a little bit of moisture from the filter into the MAF meter, thus causing the CEL. As nuke said, remove the filter and let it air dry for a while and reinstall. The CEL should go away.
Edit: I guess you don't necessarily have to remove the filter, but I would think it would dry quicker by removing it and sitting it in direct sunlight or something.
--Jonathan
