Suspension upgraded - help needed
Old Jul 15, 2008 | 03:33 AM
CraigRX8's Avatar
CraigRX8
Well i think a shock needs replace to be confirmed.
But ive wanted coilovers anyway and ive always though id go for tein super streets or monoflex as i liked the idea of being able to change dampening but now i think before i commit to buy i should have a look around
Whats everyone using? and how do you find
Handling
drivability (i.e. comfort if any)
How easy is it to ajust the heigh?
Finally price?
Old Jul 15, 2008 | 04:25 AM
DOMINION's Avatar
I don't buy Kool-Aid
Hey if I had the money I would get the KWV3 that are for sale in the for sale section. Oh yeah get the Rotas that are for sale too lol the KWV3 are life time warrenty! cant go wrong + the drifters use it on the 8. But if your not into that or tracking its kinda over kill for the streets.
Old Jul 15, 2008 | 05:33 PM
lancer's Avatar
I have the same question, But I live in Mountain area, I used to drive fast on the mountain road. What do you guys recommend for Mountain driving
Old Jul 15, 2008 | 05:45 PM
invasion08's Avatar
You dont need coilovers for street driving. They are best suited for track use since you can make a lot of adjustments. For the street. I have the Racing Beat anti sway bars on my car and it made a huge difference. But if you want to upgrade your entire suspension go with springs, sways and either mazdaspeed shocks, tokico d specs or the koni's. If you lower your car you will need better shocks then oem ones. Out of the 3 shocks a listed the tokico d-specs will give you the most adjust then the koni's and with no adjustments the mazdaspeed shocks.
Old Jul 15, 2008 | 06:24 PM
imput1234's Avatar
I ♥ Drifting!!!
KW3 or konis + some spring
are probably the most popular option around here
Old Jul 15, 2008 | 06:50 PM
invasion08's Avatar
^ what are you talking about. The KW3 is a coilover kit and comes with everything you need. There is no need to buy shocks and spings with a coilover kit.
Old Jul 15, 2008 | 10:16 PM
DOMINION's Avatar
^True dat.
Old Jul 15, 2008 | 10:37 PM
thecow135's Avatar
Duble Tru
Old Jul 15, 2008 | 10:43 PM
NgoRX8's Avatar
i believe he means those two options are the most popular around.
KW3 and Koni shocks w/ spring combo
lots of people do use Koni's
Old Jul 16, 2008 | 12:04 AM
halimsteven's Avatar
i have swift spring and Dspec combined, and i like the low and the ride.
steven
Old Jul 16, 2008 | 09:35 AM
imput1234's Avatar
I ♥ Drifting!!!
I meant that the most popular set up is either KWV3 or Konis matched with some spring. sorry for the confusion
Old Jul 16, 2008 | 09:25 PM
jstkilntim's Avatar
resU deretsigeR
I just installed the KWs and am impressed. I have them set pretty soft and it still handles better than the RB springs I had before. I have not tracked, but I will be ready if I do.
Adjusting the height takes a few minutes per wheel. Jack a corner up till the wheel is off of the ground, loosen the set screw & adjust the height. Jacking the car up is probably not required if the car is on a lift, but I imagine it makes the adjustment easier.
Price is about what I was going to pay for a inferior set w/ in car controller. Glad I changed my mind.
Old Jul 16, 2008 | 09:34 PM
All good advice here.
KW V3's try searc hing for the thread... shock shock shokc or spring spring springs
Old Jul 20, 2008 | 06:13 PM
CraigRX8's Avatar
CraigRX8
can you adjust hard soft setting on the kw's
Old Jul 20, 2008 | 09:13 PM
jstkilntim's Avatar
resU deretsigeR
Rebound, dampening & ride height are all individually adjustable.
WingleBeast
22
May 23, 2016 09:22 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
MolecularConcept
Jul 26, 2015 09:09 PM
AussieGray
Jul 16, 2015 03:58 AM
