RX8 immobilizer system
Old Jul 12, 2008 | 01:44 AM
f150rx7's Avatar
Is there away to get rid off the immobilzer so i wouldnt need a key with a transponder. Is there someway to start the car without this system. Dont worry im not stealing rx8's im trying to put a renesis on an FB rx7.
Old Jul 12, 2008 | 01:53 AM
StealthTL's Avatar
Metatron
The RB 'Race' flash removes the immobilizer function for just such a use.
I have an ECU with the Race Flash already on it, which may be up for sale soon - going turbo.
S
Old Jul 16, 2008 | 01:49 AM
f150rx7's Avatar
RB=Racing Beat? is this service in their catalog? Thanks by the way for the info.
Old Jul 16, 2008 | 01:58 AM
8 Maniac's Avatar
Senior Member
yes and yes. it's under their engine mods for the 8
is the AP also capable of doing this? If he plans on sticking with the stock PCM anyways, might as well have one...
Old Jul 16, 2008 | 07:05 AM
I dont understand, why does he need to flash Rx-8's ECU when he is trying to put the 13B-MSP into his FB.
What he should do is just get an aftermarket ECU management. I think you should try Motec or F-Con V-Pro.
Old Jul 16, 2008 | 07:10 AM
alnielsen's Avatar
/\ +1
The RX8 has all sorts of sensors that the RX7 dosn't have and would be very difficult to install. An aftermarket ECU would be a better route rather than trying to get the OEM PCM to work correctly.
Old Jul 17, 2008 | 11:14 PM
f150rx7's Avatar
Im done with aftermarket parts. I have most of the parts already to do a transplant, Using an aftermarket ECU will be costly and re fabricating the engine like putting a new throttle body,tuning,OMP(dont want to premix)trigger and ignition is also a headache. This has been done before in japan. My goal is to have a smog legal FB with an rx8 engine not a race car,been there done that. Also I want to be able to use a factory shop manual from an rx8 and also purchase rx8 parts that will be available for a while.
Old Jul 17, 2008 | 11:29 PM
Good luck with a swap like that,
If you want Stock ECU to work, you pretty much have to move EVERYTHING over, including all wires and sensors.
Old Jul 17, 2008 | 11:40 PM
f150rx7's Avatar
i have. the only sensors im missing are the wheel speed sensors for the ABS module to communicate with the PCM through the CAN lines for the speedometer.
Old Aug 4, 2013 | 03:43 AM
coolx7's Avatar
sorry for reviving old thread, but just wondering how things went with removing the immobilizer and all since there wasnt any updates.
Old Aug 7, 2013 | 10:39 PM
he failed obviously.
Old Aug 20, 2013 | 11:45 AM
anthonyallred's Avatar
If i want to swap a pcm/ecu from a donor car all i need is the ecu and immobilizer module from the donor car or do i need the ignition components as well?
Mr.Durden
Aug 12, 2015 02:21 PM
gregs
Aug 6, 2015 11:43 PM
SIllver
Aug 1, 2015 07:34 PM
AussieGray
Jul 16, 2015 03:58 AM
