Is there a difference
Old Jul 11, 2008 | 02:41 PM
oo7ml's Avatar
I have two quick questions:
1 Is there a way to tell the difference between a 192 and 231. If the two were parked beside each other, is there a way to distinguish the two of them (taking into account that the person who owns the 192 hasn't added any extras to the car)
2 When you are driving the RX-8 hard, what does the beeping noise tell you:
a when to change gear
b your driving the car to hard (as in you should be trying to avoid hitting the beep)
thanks in advance
Old Jul 11, 2008 | 02:44 PM
tubingchamp's Avatar
What mawd bug?
The difference between auto and manual would be just in the gear ****/paddle shifters (so far as I know)
I love to shift at the BEEP, but don't do it TOO often, it could be hard on the tranny (I could be wrong). But it's also very good to do it and get all the carbon buildup out of your engine/cat.. The 8 makes most of its torque at the higher rev range, so it won't hurt the motor at all to redline, but shifting every time up there could stress out the tranny..
Old Jul 11, 2008 | 02:46 PM
mysql's Avatar
Doppelgänger
from the outside, the only way to tell one from the other is if one car is the base level automatic. they come with some ugly 16" rims. If they upgrade the rims, then they'll look similar.
After that, tell tail signs for package or trim are sunroof and leather seats. Under the hood stuff is not visible other than looking at the gear shifter / steering wheel area.
Old Jul 11, 2008 | 02:53 PM
oo7ml's Avatar
Automatic... are all the 192's automatic, and thanks for the replies so far... any other comments on the beeping
Old Jul 11, 2008 | 02:58 PM
Go48's Avatar
In what country are you located? As I recall, that matters as far as standard vs. high power engine offerings.
Old Jul 11, 2008 | 03:00 PM
XlYesterdaYlX's Avatar
Zoom x 2
the beeping is just telling you to shift because you're hitting redline
shaunv74's Avatar
Power!!
post '06 they started selling the 232 as an auto as well with a 6spd auto.
Oh and the beep is fine. It's how the car let's you know it's happy.
Old Jul 11, 2008 | 03:16 PM
JRichter's Avatar
Void Where Prohibited
Oversees the 192 can be a 5sp manual. I don't think he's in the US.
Old Jul 11, 2008 | 03:21 PM
oo7ml's Avatar
Sorry, i'm from Ireland
Old Jul 11, 2008 | 03:25 PM
Renesis07's Avatar
Vtak just kicked in yo!!
I 'beep' at least 3 times per day. I'm running strong at 70K.
Old Jul 11, 2008 | 04:00 PM
champi0n's Avatar
from just the stock appearance of the car... the size of the rims is a big one. Smaller rims = less power.
Sunroof = GT = powa!
MT = powa!
the beep is to warn you that you're about to hit the fuel cut off... you can drive at 9k rpm and it doesnt sound bad (nor is it bad)... that's why it beeps.... other cars at redline sound like they're screaming rape... thus they dont have a beep cuz you're going to shift it anyways.
i like to drive at redline when going around off ramps or on ramps... i feather back and forth off of readline and i hear beeep.... beeeppp... beeep...
Old Jul 11, 2008 | 04:02 PM
JRichter's Avatar
^ again, the options are different for Euro spec RX-8's.
Old Jul 11, 2008 | 04:05 PM
mikesol's Avatar
gas kilometerage
Man, isn't that a ....... glorious feeling?
Old Jul 11, 2008 | 08:10 PM
04RX8man's Avatar
Rotary Powered Countryboy
beep....beeep.....beeeep....beeeeeeeeeeeeeppppppp. ......ah a great sound in the morning!!(after she's warmed up of course)
Quiggs321
Sep 30, 2015 05:34 PM
Stubbs
Sep 27, 2015 04:06 PM
Austin22
Sep 23, 2015 04:46 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
