New engine getting installed today, anything I should know?
Old Jul 11, 2008 | 02:12 PM
turok4n64's Avatar
I Am Turok!!
I bought my 04 RX8 used with 20k miles 2 1/2 years ago, so I haven't had the experience of a new engine on a RX8. Anything I should know?
Old Jul 11, 2008 | 02:31 PM
puch96's Avatar
Search the forums... Now with a new engine, it's like having a new car... you should go through the proper break in procedures....
Old Jul 11, 2008 | 03:48 PM
champi0n's Avatar
make sure you leave the garage light on so he's not afraid of the dark in its new home
Old Jul 11, 2008 | 03:50 PM
shaunv74's Avatar
Power!!
Have them check your ignition coils, wires, and plugs. I would recommend changing the coils. Also have them visually inspect your cat. converter inside to make sure it's not melted.
Old Jul 11, 2008 | 03:57 PM
sebarx8's Avatar
seebass
From: bloomfield nj now in miami ahhhh back in jersey now jajajjaja
don't forget to put oil in the 8 after installed the new engine
Old Jul 11, 2008 | 04:32 PM
champi0n's Avatar
haha yea... hope the tech that did the work tightened all the bolts and oiled her up.... then started it and added more oil once it got sucked up into the oil coolers and what not.
it should be fine if its done at the dealership though.. they do mechanics by numbers pretty much. (Following step by step instructions on everything).
Old Jul 11, 2008 | 04:40 PM
fwo's Avatar
fwo
i see you are from murfreesboro, where are you getting the work done, and did they give you any crap about warranty?
i also drive an 04 MT that has just over 41k.
Old Jul 11, 2008 | 06:25 PM
XAreXAteX's Avatar
Is the engine completely new? Or is it "remanufactured"?
Old Jul 11, 2008 | 06:30 PM
kersh4w's Avatar
Hit & Run Magnet
make sure you rev the **** out of that new engine and drive it hard. HARD. harder than you normally throw the engine about. this will create better seals and better compression.
get the oil changed at 500 miles, 1000 miles, and 3000 miles. after that, just drive it normally.
Old Jul 11, 2008 | 06:31 PM
turok4n64's Avatar
I Am Turok!!
go to cool springs mazda and talk to jerry. I went through RiverGate and Hickory Hollow Mazda where they treated me like **** and tried to void the warranty of my engine because of a CAI and exhaust that were after market. I went to Cool Springs and they treated me like a god.
Go see Jerry now! He has done over 100 engine replacements on RX8 at this place and installs an engine and has it ready to go in 6 hours.
Old Jul 11, 2008 | 06:32 PM
turok4n64's Avatar
I Am Turok!!
remanufactured, but its at 0 miles
Old Jul 11, 2008 | 06:39 PM
expo1's Avatar
He's as bad as Can
Since its an 04 you might also want to change the belts & hoses, they have to take them off anyway. If you have not added one yet, now is the time to put in a screen to protect the A/C condenser from rocks, 04's didn't have them. The last thing I would check are the engine mounts, I had the newer ones put in when I had a motor put in.
Old Jul 11, 2008 | 07:59 PM
04RX8man's Avatar
Rotary Powered Countryboy
proper break in procedure!!!
Old Jul 11, 2008 | 09:03 PM
XAreXAteX's Avatar
dealer told me that there is zero break in on a reman.
Old Jul 11, 2008 | 09:20 PM
expo1's Avatar
He's as bad as Can
Unless its in writing NEVER believe what a dealer tells you. The attached section of the owners manual still applies to a re-man
Attached Thumbnails New engine getting installed today, anything I should know?-breakin.jpg
Old Jul 12, 2008 | 01:03 AM
Just keep this in mind, a Reman engine is basically an "used engine" that has been returned for "enter reason(s) here"
it doesnt hurt to drive it easy for a few hundred miles, gas cost a lot anywayz
Old Jul 12, 2008 | 01:48 AM
i would not sweat the reman engine...
https://www.rx8club.com/showthread.p...highlight=dyno
Old Jul 12, 2008 | 08:53 AM
Shoafb's Avatar
[QUOTE=Go see Jerry now! He has done over 100 engine replacements on RX8 at this place and installs an engine and has it ready to go in 6 hours.[/QUOTE]
Over 100 engine replacements at one dealer?
Ask him if it is mainly 04's like we see here.
Old Jul 12, 2008 | 10:14 PM
Astral's Avatar
Purveyor of fine bass
I would at least follow the 600 mile stock break-in, better be on the safe side. It may be ok if you drive it hard right away, but why chance it?
I just got a new engine in and I'm going to break it in the same as when I got the car new.
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
yapakanichi
Aug 17, 2015 09:47 AM
dbarber
Jul 25, 2015 01:34 PM
