CarAndDriver
07-10-2008, 05:19 PM
How far does the of passenger wiper spray nozzle stream go? I think the third jet, farthest to the right/outside of the car hits the bottom of the windshield and the middle one is not that great either.
It is bothersome since it doesn't spray with enough fluid to completely clean that area and so it leaves crud streaks.
I'm taking my car in for a few things next Wed. and want to get feedback in case they feed me something like "its within specs" etc.
Socket7
07-10-2008, 05:23 PM
My sprayers are all pretty strong, but some of them arent aimed very well. you can take a needle and poke it into the sprayer to adjust the aim.
My old honda accord's sprayers worked on and off depending on if the hose got kinked the last time i closed my hood.
ken-x8
07-10-2008, 05:24 PM
All the streams on mine hit the windshield about halfway up. and look pretty strong. Nicely spaced.
There are eight streams total - very appropriate.
Ken
MazdaManiac
07-10-2008, 05:27 PM
A weak stream is usually a sign of prostate issues.
WooHoo
07-10-2008, 05:55 PM
Damn MM, you stole my line!:lol2:
CarAndDriver
07-10-2008, 05:58 PM
I was wondering when the jokes would start flying. I guess I can try using the end of a plastic coated metal paper clip and see what happens.
ken-x8
07-10-2008, 06:05 PM
...I can try using the end of a plastic coated metal paper clip ...
Ouch!! Depending on which stream you're talking about.
For the windshield sprayer, that could be a little thick. You might need to look for a thinner wire - take a look at the size of the hole. Socket7 speaks wisely - that's how you aim those nozzles. Also how you clear them if they get clogged.
Ken
MazdaManiac
07-10-2008, 06:11 PM
Use a pin. Nothing bigger.
04RX8man
07-10-2008, 06:53 PM
Yeah a pin will work both my sprayers are pointed about halfway up the windshield and evenly spaced sometime i have to clean them after a wax job because of the damn wax getting in there but a sewing needle or something like that works
swoope
07-11-2008, 04:51 AM
air in opposite direction, with the hoses disconnected..
and the weak stream issue. i think they have a pill you take and go fishing, problem solved.. maybe you have to ride a bike or kayak.
beers :beer:
