Need help quick! VFAD sensor
Old Jul 10, 2008 | 11:30 AM
Vasichko's Avatar
Im in the process of installing my MS CAI.
I have taken all of the VFAD components out, what should I do with the sensor?
Plug it back into the harness on the car and zip tie it up somewhere?
Also, it is ok if I took the hose from the VFAD silinoid off the intake manifold near the throttle body and capped it right?
Old Jul 10, 2008 | 11:37 AM
Vasichko's Avatar
Oh and while im thinking about it. Should I roll the intake with the sock on or off?
Any performance difference?
Old Jul 10, 2008 | 12:22 PM
Jon316G's Avatar
Grasshopper
Originally Posted by Vasichko
I have taken all of the VFAD components out, what should I do with the sensor? Plug it back into the harness on the car and zip tie it up somewhere?
Zip-tie the harness off to the side.
That is what you should have done. No part of the VFAD assembly should be left in the car and that nipple on the intake manifold should be capped.
Oh and while im thinking about it. Should I roll the intake with the sock on or off? Any performance difference?
I would keep the sock on. No real performance difference.
It'll just keep the filter from getter contaminated and it helps with LITTLE water droplets (so don't directly spray the filter with water).
Old Jul 10, 2008 | 12:58 PM
Cattywampus's Avatar
Turbos blow!!
I pluged it back in. There is nothing there anymore jut the connection piece.
Old Jul 10, 2008 | 01:32 PM
Vasichko's Avatar
Thanks for the help but I figured it out before you guys answered.
One last question.
Where the hell did you guys put the CARB sticker and the vacuum routing sticker???
92trbolzr
May 18, 2025 09:04 AM
Evan Gray
Nov 24, 2015 01:00 AM
XianUnix
Sep 29, 2015 03:48 PM
drlubell
Sep 26, 2015 11:58 PM
