water temp sensor adapter
Old Jul 8, 2008 | 02:26 PM
Vasichko's Avatar
I tried a search and didnt come up with much.
Im in the market to get a water temp sensor, which adapter would be the best/most accurate reading?
I know Racing Beat makes one, and then there are some universals.
Old Jul 8, 2008 | 02:27 PM
Greenblurr93's Avatar
Sotally Tober
i have the racing beat and it took 10 mins to install and was very easy.
Old Jul 9, 2008 | 09:33 AM
devildog1679's Avatar
Same here. Racing beat.
Old Jul 10, 2008 | 02:50 PM
EricMeyer's Avatar
Keep in mind that you want to pick up your water temp at it's HOTTEST point. Same for oil.
Old Nov 19, 2008 | 11:41 PM
eva02's Avatar
pick up at hottest point?
Old Nov 20, 2008 | 04:39 AM
EricMeyer's Avatar
yes, think about it. you want to monitor water temp----right? You have a choice of capturing the data BEFORE the radiator cools the water or AFTER the radiator where the water has already been cooled. Very different numbers. We do both. Same for the oil temps. Capturing this data allows you to see the maximum temps which are the real temps your engine experiences.
Take a look at where the stock water temp sensor is located and you'll see what I mean.
Old Nov 20, 2008 | 05:48 AM
Sotally Tober
FYI, ive since ditched my Racing beat in favor of the Knight Sport adapter which allows you to put the sensor in the main radiator hoses. i did this for a more accurate reading (and cleaner look)
Old Nov 20, 2008 | 07:40 AM
I got the Greddy adapter and oh yes I cut my Billion water hose so I can fit it in.
Fujita Engineering's solution is easier, Since no cutting is required.
*Edited*
Old Nov 20, 2008 | 12:58 PM
Sotally Tober
i believe you need to cut the hose for the knight sports one as well
Old Nov 20, 2008 | 01:02 PM
I use the Racing Beat adapter, works great.
Old Nov 20, 2008 | 01:55 PM
Sorry my bad
I was talking about Fujita Engineering one.
Old Nov 20, 2008 | 02:19 PM
Sotally Tober
oh that looks nice, where does that mount?
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
RAE008
Sep 12, 2015 09:08 PM
