quickest, easiest, safest way to disable the 8
Old Jul 7, 2008 | 07:09 PM
Bastage's Avatar
DEVILMAN
Originally Posted by 12oclock
Okay so I'm driving down to florida next week where I'm flying to the carribean for a week and a half. I'm probably gonna be leaving my 8 at my buddy's house or his parents house. I'll most likely take the keys with me but still........what's a quick, easy way to disable the car until I get back? Particular fuse maybe? The battery is too obvious. I think a crackhead could figure that out. Thanks for any pointers.......
Room fuse and/or just disconnect the MAF. Either one will disable the car.
Old Jul 7, 2008 | 07:16 PM
NA13b's Avatar
I Like It NA
why don't you just buy an ignition kill switch
Old Jul 7, 2008 | 07:57 PM
invasion08's Avatar
What if they have to move the car?
Old Jul 7, 2008 | 08:00 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Flood it!
Let them figure that one out!
Old Jul 7, 2008 | 08:04 PM
Eccentric shaft sensor connector...hard to see...and won't run without it...and won't flood the car if they try....also it is not as obvious as a fuse or relay.....it will crank normally..but won't start
Old Jul 7, 2008 | 08:05 PM
superglue's Avatar
n00b post whore
Yup yup. Who are you leaving the car with, Farris Bueller?
If you don't trust them enough to leave the keys for an emergency, then leave it somewhere else.
Old Jul 7, 2008 | 08:17 PM
Georgia8er's Avatar
Park it in a lot you're not supposed to and let them boot it!
Old Jul 7, 2008 | 08:33 PM
04RX8man's Avatar
Rotary Powered Countryboy
take the motor out it only weights 303lbs just set in their kitchen cupboad or something....
Old Jul 7, 2008 | 08:40 PM
+1.
The bad thing is that u have to remove the airbox to access the connector, yeah if u have small hands u can reach it from the bottom, but that means u have to jack ur car up plus is a pain to try to pry the connector out
Yes Car will crank, appears to be normal. but no fuel delivery (so it will not start)
Old Jul 7, 2008 | 08:45 PM
expo1's Avatar
He's as bad as Can
A Battery-Disconnect Switch is cheap & easy.
Attached Thumbnails quickest, easiest, safest way to disable the 8-battery_cable.jpg
Old Jul 7, 2008 | 09:35 PM
atl8's Avatar
Cobb AccessPORT + Anti-Theft Mode map. It's not cheap, but you can't tell what someone has on here just by their post count. Most everywhere I lived in South Florida is as flat as Paris Hilton so you could still leave them your key and they can push it if they need it moved.
Old Jul 7, 2008 | 09:43 PM
champi0n's Avatar
disconnect the fuel pump connector
Old Jul 7, 2008 | 09:46 PM
hakuna matata!
^ +1
Old Jul 7, 2008 | 10:38 PM
Leave it with someone else.
He's not your friend if you can not trust him.
Old Jul 7, 2008 | 10:41 PM
champi0n's Avatar
take a tire with you... i do it all the time with my bicycle.
Old Jul 7, 2008 | 11:23 PM
lilring's Avatar
Finally a MT
^ +1
thats what i do and its has never failed me
Old Jul 8, 2008 | 12:54 AM
Zerotide's Avatar
Snick-Snick Gearbox
Just take the key and make it very clear to him you know specifically how many miles are on it and if that number is any different when you get back there will be blood!
WranglerFan
Aug 21, 2022 01:29 PM
ErwinN
Sep 23, 2015 09:29 PM
Mr.Durden
Aug 12, 2015 02:21 PM
