Eccentric Shaft Pulley Seal Leak
Old Jul 7, 2008 | 05:45 PM
NA13b's Avatar
I Like It NA
Has anyone else had this problem? The dealer near me says it will be about 1400.00 to repair.
Old Jul 7, 2008 | 05:59 PM
champi0n's Avatar
I haven't had this problem with an rx8, but i've had rear main seals leak on piston engines.
Is it the rear seal that's leaking?
if its "rear oil seal" you have to remove the transmission, flywheel (MT) (or driveplate -AT)
Old Jul 7, 2008 | 07:13 PM
NA13b's Avatar
I Like It NA
Nope, they say its the front seal, right above the oil pan gasket. They say it a really small leak. The only way they were able to find it was when they noticed some oil on the oil pan. I was having it inspected to make sure everything was ok with it. It has about 70k on it.
Old Jul 7, 2008 | 07:30 PM
Mine leaks on the track...when it's at high RPM's and hot for a long time....
I replaced the seal and it still does it a bit...It isn't much...so I just leave it alone...not likely to become a big problem fast
Old Jul 7, 2008 | 07:31 PM
you sig is spam you need to take it down.
Old Jul 7, 2008 | 09:30 PM
Old Rotor's Avatar
The engine now has a 8 year 100K mile warranty....were you aware?
Old Jul 8, 2008 | 05:43 PM
NA13b's Avatar
I Like It NA
The dealership is saying because I am not the original owner, the warranty will not cover my car.
Old Jul 8, 2008 | 05:51 PM
quazmosis's Avatar
Chode
^ I would argue that, or call Mazda USA.
Old Jul 8, 2008 | 05:56 PM
jzief128's Avatar
What are the Detes?
I thought that only including rotary "core components". This seems like something that would be excluded from the core. I could be wrong though.
Old Rotor's Avatar
The dealer is wrong, call Mazda the 800 is in the manual....
Old Jul 8, 2008 | 06:03 PM
CyberPitz's Avatar
Huge hole is huge
Woooaaahh, call them on that. They are trying to cheat you outta some money!
Old Jul 9, 2008 | 12:00 AM
Soapflake's Avatar
Bitch, raise hell and then bitch some more. You can't just void a warranty because the car is sold...
92trbolzr
May 18, 2025 09:04 AM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Tgiolitto100
Sep 29, 2015 10:52 AM
pjwermuth
Sep 28, 2015 11:36 PM
DG07
Sep 28, 2015 10:58 AM
