Tire NO squeal and tire NOW squeal?
Old Jul 7, 2008 | 03:12 PM
ShottsCruisers's Avatar
Rx7 and now Rx8
Confused? I luvved the Dunlop SP Sport 8090's on my '06. Why? No matter what I did they NEVER squealed and therefore no tickets.
So, since I figured that a GREAT perk, I bought a new set at 28K without considering other makes.
The trouble? If you get aggressive while turning or taking off, these new ones SQUEAL! Errr!
I emailed Dunlop/Goodyear and they stated that no changes have occured in the 8090 model tire. No rubber change. Nothing.
WHAT GIVES?
Old Jul 7, 2008 | 03:15 PM
SideOfBacon's Avatar
tire pressures?
Old Jul 7, 2008 | 03:17 PM
Rx7 and now Rx8
Originally Posted by caveney
tire pressures?
Old ones wouldn't squeal at any PSI. I tried the new ones at 32 and 35. Squeal.
Old Jul 7, 2008 | 03:21 PM
Haze's Avatar
If they are really new, new. It takes hundreds of miles to wear off all of the manufacturing resist from the outside of the new tire. It could be that. If you have run them over 800 miles, beats me.
Old Jul 7, 2008 | 03:23 PM
Rx7 and now Rx8
So it sounds like you've heard or know that the 8090's don't squeal?
Old Jul 7, 2008 | 03:24 PM
luv4eternity's Avatar
Low is a lifestyle
probably is the new layer .....need like a couple hundred to get them in good shape ...
i'm just guessing ...
Old Jul 7, 2008 | 03:25 PM
alnielsen's Avatar
Even though they have the same model number, the OEM tire and the replacement model tire are rarely the same. The OEM is made cheaper as to cost the car manufacturer less.
Old Jul 7, 2008 | 03:40 PM
Haze's Avatar
No. I'm accepting your assertion that your last set didn't, and I am trying to point out that a new set needs to wear the resist, which is used in manufacturing, off before they will run normally.
That was all I was trying to say. If you have run them around enough, then I don't know why the two tires would act differently.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
