newly bought rx-8 highpower hmmm
Old Jul 7, 2008 | 03:15 AM
jonr-'s Avatar
what a car. love it! Im writing all the way from norway. As some may have experienced, the rx-8 is kinda seldom car here in norway. Its only registered 134cars.. That number might be a lot higher down in the usa :P
Well. I drove the car 7hours two days ago on my way home from where I bought the car. The distance is over many mountains with MANY curves (you know, in the road, have to turn left/right alot). ...(my english isnt the bestest:P )
smooth gearshift, rotary/"superbike" engine sound and 50/50 balance in the chassi is was all needed to hold my big smile all the way home :D FUUnnny!
__________________________________________________ ______________
The only thing is.. well its 3 things..
1. right front light (the whole plastic container with the light bulbs in it) is soaking wet. A big "hole" is letting water in.. and the two back lights are also taking in some water.. its minimal though..
- solution. The seller already fixed 3 new light holders/containers/orwhatyoucallit for me.. should be in the mail within a week..
- question #1
is it hard to change the lights? I think its easyer to change the two backlights, but in front? im not a mechanic, nor a english teacher...
____________
2. when I arrived and parked besides a buddy of mine. he heard a strange clackclackclack/bad noise/scrambling sound from under the car. WHEN I HELD THE CLUTCH IN the sound disappeard. Im pretty sure it is the thrust "thing". If you guys understand what I mean..?
- solution. take it to the mazda mechanics..expensive? maybe.. :O
-question #2
- Can I drive around with the defect/soon defect thrust "thing" (dont know the english word for it). Does that make any more damage to anything under there?
________
3.1 When driving from 0kph til the redline IN 1. GEAR. ( very easy on the pedal.. not full throttle). I experience some sort of "mini-jumping-forward" its almost the same symptoms as a fully tuned car having full gass with to little fuel.. kinda like fuel cut, but not so bad. this is just dumb.. I dont believe anyone will understand this loong letter.. :P The "jumping" (again, cant the english word for it) is most when 1.gear in about 1000rpm - 4000rpm.
3.2
Some times this also happens when I drive NOT WITH FULL THROTTLE all the way up to 7000k.. It makes a little bittle jump when passing 7000k..
-question. what can this be? =
_____
4. And ALSO in 1.gear when I got max throttle, max rev. when the rev meter is showing about 7000rpm - 9000rpm, I can hear some times a little weak sound of some electric.. VERY hard to explain... so I give up..:P
like I said.. Its a weak electric,alien,voice coming from the engine OR in the car.. dont know..
-queastion .- help ?
Looking forward to get alot help from my rx8 comrads in the united states
best regards - jon!
Old Jul 7, 2008 | 04:15 AM
Spinning Sushi's Avatar
I <3 Sushi
1. It's really easy to change out the lights in the front. Just remove the fender lining, squeeze the clips (assuming your car came with HIDs), twist and pull out.
2. As for the noise you hear from underneath your car when the clutch pedal is depressed; that's your throw-out bearing. It's normal for the RX-8 to have that noise.
3. For the third question, maybe you're lugging the car? When you're not familiar with the car, they tend to make the car lug or jerk alot depending on how hard you step on the throttle as well as what RPMs you're in. This requires alot of practice and getting used to.
4. Maybe you're getting detonation? Does it sound like a bunch of sand moving inside a can? If it does then that means you need to use better gasoline. Your spark plugs and plug wires might be worn out as well, I recommend trying a higher grade gasoline and if you still get that then replace your spark plugs and plug wires. If that doesn't work, replace the coil packs which are very expensive. The coil packs should be covered under warranty though.
Old Jul 7, 2008 | 04:38 AM
jonr-'s Avatar
Hmm.. do you mean the WHOLE "light-package"? I dont need to change only the lights, but altso the little "cover/cointainer/holder"box/ that the lights are sitting in.
IS that soo? :D So when the clutch is "depressed" (dont really know what that means, but its the same as "not having you're foot on it" ? )
, the sound is just normal? :D so very nice to hear. A mechanic thought the sound was the sound of a soon broken thrust - throw-out bearing.
That can be very true, but the first miles I drove it, I cant remember to have that lugging... (lugging was the word I where looking for.)
Ok. It can be detonation. I dont know.. I'm using no led, 95. Its the ordinary fuel for cars in norway, expect diesel cars.. maybe I should use 98 octan then. I'll try that next fueling :D
btw.. thanks for VERY good answers!
Old Jul 7, 2008 | 06:17 AM
jonr-'s Avatar
the noise from under the car..
Talked to a mechanic over phone and he said that if the sound disappeared when I hit the clutch, it wasnt the clutch - thrust bearing that made that sound.
...it was the gear system..... he said he was absolutely sure.. :O
any other feedback, guys?
-jon
Old Jul 7, 2008 | 07:08 AM
Falken's Avatar
Drop it into 3rd
Some extra exhaust ports open up at around 6krpm, that's whats probably causing the little jerk up there. I get it too.
Old Jul 7, 2008 | 09:33 AM
SpIcEz's Avatar
Hi jonr-
Congrats on your purchase.
Im having the same problem you are.
clack clack sound, when clutch is engaged to the tranny. If I PRESS on the clutch pedal (DISENGAGING THE CLUTCH FROM THE TRANNY) the sound stops.
Im also told it means its a transmission problem, not clutch or throw out bearing.
Im bringing it in next Monday (July 14th) to my local Mazda dealership to see whats up. Car is still under full warranty.
As for the fuel 95 RON is more than enough, as it equates to 90-91 Octane here in North America, and 91 is generaly the highest you get anywhere, and is what WE call super. And even for us, Super is only suggested, many run 89 Octane (probably around 91-93 RON) without any problems either.
Im in Montreal Canada, and Im guessing we get around the same temperature/seasons you get in Norway.
Id stick to 95 RON.
Check the RX8 owners club in the UK or the France RX8 club as well for more info (if you read french).
http://www.rx8france.com
http://www.rx8ownersclub.co.uk/
Old Jul 7, 2008 | 09:57 AM
jonr-'s Avatar
The noise from the "clutch"
I went to an mazda dealer now, and he told me that it was a thing in/with the transmission. And he recommended that I should not take it into service becouse of that. Partly bevcouse the of the problem wasnt that big, and partly becouse of the questions around wether this is going to be an insurance/quaranty case.
So to all of you that got this sound. It seems to me, that you might get it covered on the quaranty (i know its spelled wrong), but you also might not..
And the positive thing is that cars can drive around with this problem 200 000km without needing to change the "bearing" (dont know if thats the right english word for it). Thats what the mechanic at the mazda said to me.
Im just bringing it further to you as a tip, not an answer
ehh.. gay smiley
well... Gotta admit that it is little bit disturbing knowing you got a problem with you're car when you drive around.. Irritating would be the right word.
Old Jul 7, 2008 | 10:00 AM
jonr-'s Avatar
Originally Posted by SpIcEz
Hi jonr-
thanks for nice answer Then i'll continue to fuel with the 95 oct. I'm gonna fill it with 98 next fueling, just to see if there's any difference though
and give me info after you had the car to the mazda mechanics, please? :=)
Very very interesting to hear the mechanics opinion
Old Jul 7, 2008 | 10:03 AM
04RX8man's Avatar
Rotary Powered Countryboy
That sound that you 2are worried about is the throwout bearing everyone 8 owner that has a 6 speed has the noise it is common on all 8's nothing to worry about u just learn to not pay attention to it...
Old Jul 7, 2008 | 10:07 AM
dozer's Avatar
on his 3rd rx8
that noise from the clutch is normal....its like you hear nothing when your clutch is depressed and a noise when its not, thats normal, i had 2 8s and i exprienced the same thing....youll be fine
Old Jul 7, 2008 | 10:09 AM
jonr-'s Avatar
that might have been this months best answer!
are you 110% sure? its kinda lame that every mechanic I talked to around here says that I should change it. that sound isnt good. and so on.
But you might have more knowing about that rx8 than the mechanics that usually changing oil on the audi stationwagen, volvo family car etc.
Old Jul 7, 2008 | 10:10 AM
dozer's Avatar
on his 3rd rx8
and for 3.1 i believe your letting go of the clutch to fast...ease on it a lil and get used to it, i had the same problem when i first got the car, as the months went on i got used to it and i no longer make it "jump"
Old Jul 7, 2008 | 10:12 AM
jonr-'s Avatar
very nice! problem solved.. Should be enough that 3 ppl saying its "ok".
Old Jul 7, 2008 | 10:29 AM
dozer's Avatar
on his 3rd rx8
OH YEAH!!!! PARTY TIME!!!!
Old Jul 7, 2008 | 10:35 AM
XAreXAteX's Avatar
Rx8Club: Strengthening Norwegian and U.S. Relations Since 2008
Old Jul 7, 2008 | 10:40 AM
SpIcEz's Avatar
Hey, Canada too!!!!
BTW, just to confirm...
From MOST of the posts Ive read about the throwout bearing sound, people describe it as a whine....
What I and I think jonr- is talking about here, is the whine, but also a clack clack clack sound.
I really dont want to sound like I dont have confidence in what you guys are saying but I mean, if something is making a clacking sound, it means something is hitting or rubbing something it isnt supposed too... cant be good in the long run...
or am I really off base... ?
Old Jul 7, 2008 | 10:59 AM
Silver06's Avatar
Zoom Zoom....
Hi.
There seem to be three 'common' complaints about clutch/tranny noise. None of them are really bad, just annoying.
The problem with noises is that they are often subjective to each owner. Try to be around other RX8's and speak to their owners / listen to their cars.
1. Throw-out bearing. This transfers the energy from the (rotating) clutch to the (stationary) clutch fork. This can be often described as a whirring or rattling when your foot is off the clutch, but can also be a slight squeal noise, when your foot is just starting to press the clutch. The only solution is a new bearing, which may or may not start to make the same noises within weeks, or never.... They don't often seize, just stay noisy for the life of the clutch. I wouldn't pull the transmission just for a slightly noisy t.o.b., but will always change it when the trans is out for any other reason (eg. clutch).
2. Clutch fork. The lever that connects the clutch slave cylinder with the throw-out bearing. This is like a rattle when the clutch is not pressed. Some heavy grease in the area where the pin from the slave cylinder presses the fork may help, for a while.
3. Transmission rattle. All manual transmissions have some rattle, the location of the RX8's transmission, and/or mounting and/or a thin case and/or gear play, seems to make this rattling more noticeable. There is play in the gears, and a shaft in the trans that rotates when in neutral with your foot off the clutch to keep the synchros for first gear spinning. This rattling may be more noticeable when the car is cold - the oil has dripped off the gears, and is thick - the rattle goes away as the trans warms; or when warm - the oil has thinned and loses viscosity.
The first step to diagnosing // quieting a noisy transmission is to replace the gear oil. Trans fluid changing is a maintenance item (every 30,000 km according to my manual), and not a difficult DIY. I suggest that you change to a quality synthetic fluid. I like RedLine 75w90NS.
In my current RX8, I have a little bit of transmission rattle when the engine is cold and at high idle. I notice it in my quiet garage... When the car is warm, I don't seem to notice it much (I guess I just tune it out) LOL....
Good luck!
ps. Note that there are also some other noises that can be expensive, like the input shaft bearing, clutch disk springs broken, etc. It is always best to have someone with lots of transmission experience make a diagnosis if you hear any new noises...
Old Jul 7, 2008 | 11:37 AM
immigrant6906's Avatar
From Across the Pond
Unless I'm mistaken, it sounds like you are describing the shift buzzer that alerts you when you are close to redline. I think it kicks on at 8500 or there abouts.
Old Jul 7, 2008 | 12:07 PM
jonr-'s Avatar
hehe! are you making fun of me? I know I can sound a little bit 13-years old when you're reading through my posts thats full of grammar error, but come on:P
Let me just answer this is in a polite way: - no, it's not the shift buzzer...
Old Jul 7, 2008 | 12:36 PM
jonr-'s Avatar
As im reading thorugh you're post, silver06, I came to think about yesterday when I stupidilly forgot my rear "floor carpet matt" (the thing thats lying on the floor where people have their foots) - on the vacuumer machine at the fuelstation... I vacumed my car after I had som friends in the back and ready to leave I forgot that I had that "carpet" left on the machine.. 2 hours after when my brain usually starts to remember important things, I went back to get it.. To my half-big surprise the "carpet" was not there...
The reason I came to think about it, is that you're the type that actually would go into the gas station and leave it behind the disk for the rightfull owner to get it when he's coming back looking for it. I can tell when I read you're good long post.
I'm actually pretty surprised over this good feedback, all this answers you get here at rx8club. At the norwegian mazda forum, I havent got a answer for my easy question, and that easy question did I ask for over 2 days ago
So this is a (might be a little bit off, but you deserved it:P) clap in the back for the nice "help-other-rx8-owners-spirit" here at this forum. ( I didnt se where or when you where supposed to use this smiley, but it's all falling to peaces now:P )
This post is either percieved totally gay, or as an fine gesture.. hehe.
Old Jul 7, 2008 | 12:39 PM
champi0n's Avatar
the clutch noise is definitely the throwout bearing, many cars have this "problem"... can be adjusted to go away.
Old Jul 7, 2008 | 12:44 PM
kersh4w's Avatar
Hit & Run Magnet
the rx8club is the premier online rx8 forums, if you cant find the answer here, you're simply asking the wrong question.
Old Jul 7, 2008 | 03:51 PM
Silver06's Avatar
Zoom Zoom....
jonr-
Thanx.
We're all in this together.
Old Jul 7, 2008 | 04:47 PM
CyberPitz's Avatar
Huge hole is huge
Awwwwwwwwwwww, this is a cute thread! :D
pretty much, what everybody has said is the truth...it will make that noise.
I hope the higher octane fuel fixes your high RPM noise! I have no idea what it could be.
Old Jul 7, 2008 | 05:06 PM
dozer's Avatar
on his 3rd rx8
^him farting as the throttle response from the 8 puts him back in his seat
