have some problems with the clutch!need help!!
Old Jul 4, 2008 | 02:12 PM
rx8rx8rx8's Avatar
last night my son took my car and he came back by the tower truck...
I went to the dealer store and they told me that the clutch burned...they ask me to get new clutch from them for like 1000$ or something.but I have checked on ebay that EXEDY clutch are like 300$ ish so I think I better get a clutch kit myself on ebay. but just have 2 questions!
1. The clutch is not under warranty? Mazda say that I am the one who uses the clutch kit. and this part is not covered.
2.which EXEDY clutch kit I should get? EXEDY OEM or the stage 1 kit?what is the difference between them?and if I should replace other parts other than the clutch kit??
Old Jul 4, 2008 | 02:18 PM
RojoOcho's Avatar
Greensboro's Finest
I don't THINK a clutch is covered. I'm sure someone will chime in. But that's subjected to wear and tear. It would be like them covering the tires.
Old Jul 4, 2008 | 02:23 PM
YaXMaNGTO's Avatar
It's a Cavalier
Don't listen to this guy... he doesn't even have an RX8.
rx8rx8rx8
How many miles are on the car? Major determining factor on warranty replacement of clutches.
Old Jul 4, 2008 | 02:24 PM
RojoOcho's Avatar
Greensboro's Finest
rx8rx8rx8
Hahahahahaha.... Oh you....
Old Jul 4, 2008 | 03:58 PM
04RX8man's Avatar
Rotary Powered Countryboy
I THINK the clutch is only covered for like 12,000 miles or something...personally I would go with a stage one clutch over oem anyday..a little stiffer yet still able to b driven everyday!!!
P.S. sounds like ur son needs lessons on drivin a stick hahah....j/k
Old Jul 4, 2008 | 08:39 PM
rx8rx8rx8's Avatar
so to replace the OEM clutch kit with the stage 1 kit from EXEDY.no modification is required??
Pressure Plate , Full Organic Clutch Disc ,Release Bearing ,Pilot Bearing ,Alignment Tool ,Grease Pack these are all the parts I need to replace the OEM clutch?no other parts missing??
Old Jul 4, 2008 | 08:42 PM
8 Maniac's Avatar
Senior Member
If you have the money, go ahead and get a lightweight flywheel. If you're at all interested in aftermarket parts, that would be useful to go ahead and get now if you dont mind spending the money on it.
Old Jul 4, 2008 | 08:48 PM
04RX8man's Avatar
yeah while the tranny is already off and ur right at the flywheel i would def go for the lightweight flywheel if u have the money!!! Everything should b with the clutch kit everything u need just piece it together and ur ready to go? Ru planning on doin the work urself?
Old Jul 4, 2008 | 08:50 PM
CompMan's Avatar
iDüber
Clutch isn't covered. Just went through this. Blew my clutch.
Got it towed to the dealer. $1400 bucks for Stock Clutch and flywheel.
I would of got an after market one, like an act prolite kit, but the towing to a place that would put it in was ridculous. So I'm going to wait till I turbo my car for the new clutch.
I hate the Mazda Dealership by me, when I got the car back the exhaust wasn't even tightened. I'm driving and its way louder and normal so I brought it back and the yahoo behind the counter gave me a dirty look and said I doubt it but we will look at it.
So I went into the garage with the guy that did my clutch, he threw it up on the lift and hes like "oh I musta forgot to tighten that" I wanted to say oh yeah what else didn't you tighten?
Old Jul 4, 2008 | 09:04 PM
04RX8man's Avatar
1400 bucks for an OEM clutch is ridiculious i would have changed that sh*t myself hell 500 bucks for like the best clutch out there and had another 900 bucks for gas or something else
Old Jul 4, 2008 | 09:17 PM
CompMan's Avatar
iDüber
If I knew how to do it bro I woulda
Old Jul 4, 2008 | 10:03 PM
jones75254's Avatar
While ur at it you might as well get the SS clutch line
WranglerFan
May 31, 2022 07:51 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
